Question about Logitech R-10 Computer Speakers
No sounds on my speakers
I have ms need help as iam home alot .Miss my sound from my speakers.My speakers are logitech .r-10 iam a computer dummy. I tried every thing.Thanks ever so much . flo
  • 42 Answers
1. Power to the speakers (make sure they are plugged in!)
2. Make sure the speaker line is plugged into the correct port on your sound card. The connector should be green and possible the port will be green to.
3. Double click the little speaker in the bottom right of the screen (assuming you are using XP/VISTA) and make sure nothing is muted.
Post back with your results.
Posted on Jun 03, 2009
Logitech speakers not working no sound
Turn off the speakers. Restart the computer with the speakers off. Once fully booted turn on the speakers. I had this problem where with the speakers on when the computer was started the sound card was not even recognized. Loading drivers had no affect. Good luck.
Nov 16, 2010 | Logitech Z-10 Computer Speakers
No CD and cannot find driver for Logitech R-10 speakers-HELP
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Download the drivers from this link
http://www.logitech.com/index.cfm/downlo...
if you still have a problem try
http://logitech-en-amr.custhelp.com/cgi-...
Hope this helps :)
Sep 15, 2009 | Logitech R-10 Computer Speakers
I've lost sound in one speaker
Check the wire for frays, missing insulation, broken area, loose fitting, etc. It sounds like there is something that is not making a proper connection. "Fiddling" makes it better leads me to believe that a bent area, frayed wire or such has it not making a full connection. You may need to replace the wire to that speaker in order to correct the problem. If the unit is still in warranty I'd suggest contacting a Logitech repair center for this. If it is not then you can do this yourself if you are comfortable working with a soldering iron. Just make sure you use properly rated speaker wire and connect the wires properly. Hope this helps.
Sep 13, 2009 | Logitech Z-2300 Computer Speakers
I need drivers for logitech x-530 for my pc .. xp home-edition
they are speakers, why do you need drivers.
Maybe you don't understood well:
Frequency Directed Dual Driver (FDD2) satellite technology: Produces a uniform sound field, eliminating uneven response to deliver a fuller, richer sound.
Jun 26, 2009 | Logitech X-530 Computer Speakers
No sound from logitech X240 speakers
start with the easy stuff to miss...wired correctly, power on (green light on the right speaker) Do you have it plugged into the GREEN socket on the rear of you computer, Is there an X in the mute box, double click on the speaker and check, do you have a splat in sound codec or any other sound component Now are you running XP speaker in a Vista world. If you are cool up to this point, Update the drivers from logitech or Acer. Logitech says they are not compatible with Vista...that could be it...
hope something here helped and got you up and listening. please leave rating.
May 10, 2009 | Audio Players & Recorders
Logitech R-10 speakers sound problem
in control panel, go to hardware and sound, click on realtech audio manager with your logitech speakers plugged in, and then you should be able to chose your speaker configuration. If that doesn't work, try going to sound, and configuring your speaker setup there. Realtech has different settings you can click on, including volume, as well as various equalizer settings which you choose if you want to sound like you are in a sadium, bathtub, etc.
Mar 09, 2008 | Logitech R-10 Computer Speakers
Head set problem with vista
you will need to go into the sound manager in control panel and make sure that the external mic is enabled as the default use and ensure in the sound settings that the mic is not muted, this is normally done by right clicking the speaker icon in the taskbar and selecting options and see if the mic is muted or not in the properties
May 26, 2007 | Logitech Premium Stereo Consumer Headset
Mar 07, 2007 | Logitech R-10 Computer Speakers
Logitech mm50
I think maybe the speakers blew out because of how loud people put there IPods. It is busted so buy a new one.
Jan 19, 2007 | Logitech Inc MM50 Portable Speakers iPod...
Logitech R-10 Computer Speakers Logo
190 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
