SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
SOURCE: Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
SOURCE: Fridgidaire GLET1041AS1
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
