Question about Whirlpool Duet GHW9150P Front Load Washer
Will not drain
F21 error will drain a little than also get a 5d error message
  • 6,784 Answers
Check the following to address this issue-- 1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). 2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 04, 2009
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
F21, 5d, and not working
remove the bottom panel 3 scres and you will see it check the filter there for a blockage
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERER CODE 5D?
Whirlpool Duet Sport ht 5D/F21 Error Fix - YouTube
? 5:40
https://www.youtube.com/watch?v=2dV3FLzWPTM
Aug 6, 2013 - Uploaded by Mariela Gonzalez-Aroche
Steps in this video may be used to repair both F21 and 5D error codes. ... which is located on the bottom right corner of thewasher machine.
Nov 01, 2015 | Washing Machines
Hi We have a Kenmore HE2 plus front load washer. Its not too old but it came with the house. Recently we have been getting error messages 5D, F21, and F23. I pulled off the front panel and cleaned out...
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Sep 06, 2011 | Kenmore HE2 Plus Front Load Washer
My whirl pool duet sport keeps having an error message of f21 and 5d. i read that it means the water is not draining right. what can i do to fix this?
F21 means to a long drain.
Basically means that water is not pumping out quick enough. If all the drain lines have been checked for blockages and restrictions the manufacturer recommends the pump is replaced. Some times the impeller can become damaged or the motor which can cause the pump to work slower then it should causing this error code. If you took off the hose from the tub to the pump and found nothing then I doubt there is a blockage in the drum (it would have moved into the drain filter).
Sd or 5d error SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Hope this helps.
Aug 15, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a Kenmore HE2Plus - it is 6 years old. All of a sudden two days ago I got up to a load of laundry not done, full of water and the code F21. We have gone through most all of your suggestions. At...
The Sd code appears when sud is detected but it may also indicate draining problem such as blocked drain filter or broken drain pump as signified by the long drain error code F21. The drain pump impeller may be broken or restricted resulting in poor draining or no draining at all or the drain pump motor is faulty. Since the drain hose and filter have been cleaned but the error code still persists, the drain pump likely needs to be replaced. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing
Jun 18, 2011 | Washing Machines
Kenmore Washer 110.4512600, what does code F21 mean? ( 5d?)
If this is a Kenmore Elite front loader series washer, "F21" is a Long Drain error code. This may be an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Feb 11, 2010 | Kenmore Washing Machines
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21, 5d, and now not working
I had to call the Whirlpool service man. He came and concluded that the control panel was the culprit. He said it could be that the contacts were bad, but he didn't want to unstack the washer/dryer (dryer is on top of washer) to check it. He was suppose to call me to day with a price for another control. I'm just going to go and buy another machine. Can you recommend a reliable front loading washer?
Thanks for all your help!!!
Judy
Whirlpool Duet GHW9150P Front Load Washer Logo
129 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
