Question about Compaq Armada E500 Notebook
My usb port of my Compaq Armada E500 Laptop no
The usb port of my Compaq Armada E500 Laptop no longer works properly. whenever i insert a flash it says usb device not recognized.
The usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Posted on Jul 09, 2009
My compaq armada e500 is not opening my Sandisk thumb drive.
Plug the drive in and leave it for a while as windows tries to read what it is. It should recover in a few minutes. If not try a different usb socket.
Sep 07, 2015 | Compaq Armada E500 Notebook
How do i connect crw-785 to compaq armada e500
This e500 has USB1.0 and transfer rate will be slow. If you use Win 98 then install the USB driver (get on web) first. Install software then plug in the USB lead from the crw-785 and don't forget to plug in the DC adaptor for the drive, (e500 USB port does not have enough power to run external drives other than some older thumbdrives).
Feb 24, 2015 | Compaq Armada E500 Notebook
Usb stivk doesn't work
It seem to be a driver problem reinstalling the driver should resolve the issue.
Nov 02, 2010 | Compaq Armada E500 Notebook
Which card do I need to buy to make my Compaq Armada E500 wireless?
1. If your laptop has a USB port that supports 2.0 USB device you can purchase a
Trendnet Wifi adapter that connects to your USB port and comes with a wifi utility disk
to help you setup your wifi. I have purchase two of these unit and they work well.
I have a D600 Dell and it's wifi drivers became out dated and I purchased the Trendnet
and now can connect to just about any wireless B/G/ N routers.
It's cost vary about $10.00. You can visit this site below and purchase it and have it shipped
if you don't have this store in your area. You also can return it within 30 days if it doesn't wo
work for you.
http://www.microcenter.com/single_product_results.phtml?product_id=0307841
Oct 11, 2010 | Compaq Armada E500 Notebook
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
Windows 98 se, xp not installed to compaq armada E500 pc notebook
First, format the hard drive and make sure it is in FAT or FAT32 for Windows 98 install. Then do your partitioning etc and should work. If it doesn't, it is possibly a hardware fault.
Here is the site for the drivers for the laptop :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=1093
Hope this helps in some way :)
Jan 05, 2009 | Compaq Armada E500 Notebook
USB Connector
that or you could also try discount electronic stores for a usb PCMCI card to add in, then you have the added bonus of USB 2.0
Apr 21, 2008 | Compaq Armada E500 Notebook
Compaq Armada E500 PC Notebook usb port problem
If the usb connector / port is only damaged it should be a fairly easy task.
Your going to need a few screwdrivers to get the laptop open
and a soldering iron, to remove the port or ports connector(s)
from the motherboard then replace it with a new connector.
if the motherboard is damaged you would most likely have to replace the whole motherboard and that would be way too much money for a few usb ports.
the usb connector only has 4 pins
http://wolfstone.halloweenhost.com/Audio/mpg016_ConnectorUSB.bmp
Mar 30, 2008 | Compaq Armada E500 Notebook
Compaq Armada Serial Port Broken
Do you really need the serial port? You should be able to find a USB to serial converter fairly cheaply.
Sep 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
570 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
