Question about Kenmore Vacuums
Vacume overheats and shuts down I replaced the motor.When it cools down it runs again.
The filters had to be cleaned out with air.
I replaced the motor for nothing.There are two filters and the cannister give them good cleanings with an air gun.
Posted on Jun 04, 2009
I have a Fantom Thunder TH469KA and it shuts off after 5-10 min of running How do I fix this?
on all vacuum cleaners the air flow cools the motor. If the filter is sufficiently clogged there would not have enough air flow to cool the motor and trips out from over heat. Clean out the filter thoroughly and try again.
Jan 01, 2015 | Fantom Vacums Vacuums
Seems to overheat and shut down
clean the hose very well that is sure to fix you problem I repair vacuums for a living this is very common do not use it again until you clean the hose really well stick a pole to a broom all the way through the hose and rinse the filters in hot water and let them air dry and it will run like normal when you push the broom stick through the hose it will free it of any debris if this does not work it is trash
Mar 19, 2014 | Vacuums
Overheat light comes on vacume will not run
Let it sit for 30 minutes before trying to use again. Make sure the bag is not full and check to see if filter is clogged.
Oct 27, 2013 | Electrolux UltraLux 2000 Bagged Canister...
My hoover harmony overheats and stops running. when it cools down it can be started again = what seems to be the problem? is there anything I can do to troubleshoot?? please help
clean it out.
There's probably something jammed up in there
What were you vacuming when it originally went out or what is the typical items (other than dirt) which you are not picking up prior to vacuuming?
best regards
Ck
Aug 18, 2011 | Hoover Vacuums
Is it possible to overheat the motor?
This can happen , normally if the filters are kept clean and replaced now and again the motor should last quite a few years if it does overheat then it has a thermal cut off that resets after it cools down ,,Hope this is of some help
Feb 22, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Shuts off after 15min
the motor protection 1st has to be replaced
Mar 06, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Shuts down after 10 min use
I would clean or replace filters on it check the hose to make sure it is not blocked . It sound like it is over heating and making the breaker kick off and after it cools down it resets this is caused by dirty filters or blocked hoses.
Feb 22, 2009 | Hoover U5753-900 WindTunnel Bagless...
Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Oct 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacume Overheating
There will be a filter between the cylinder/bag and the engine. If your vacuum has a HEPA filter there will be one on the other side of the engine. Remove both of these and clean them out with water, allow to dry and replace.
Jun 18, 2008 | AEG Vacuums
Vacuums Logo
132 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
