Question about Frigidaire FRT15G4B Top Freezer Refrigerator
Leak in samsung refrigerator under veggie drawer
Water pools under veggie drawer and runs out onto floor. Happens several times a week.
SOURCE: Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Posted on May 13, 2009
  • 72 Answers
SOURCE: why is water forming under the veggie drawers
One of two things caused this problem, either the drain in the freezer is clogged and spilling over to the air duct and through to the refrigerator, down the back wall and then puddling up under the drawers or the Styrofoam between the freezer and refrigerator is saturated with water. If you remove the inner back wall of the freezer and there is ice built up, defrost it with hot water and a turkey baster, push some heavy weed trimmer line down the drain tube and they should clear the clog. If there is no ice build up, then you probably have the latter of the two problems, the only solution is to empty the unit, turn it off, and let it dry out for a few days with the doors opened. If the problem continues, then there is a significant breakdown of the Styrofoam between the two cavities and there isn't a solution, it is time to purchase a new unit.
Posted on Jun 16, 2009
  • 4793 Answers
SOURCE: Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Posted on Mar 08, 2010
imufo2
  • 3773 Answers
SOURCE: samsung model#rs253basb side by side/
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 16, 2011
oldTech2332
  • 2341 Answers
SOURCE: Water is draing to the
The source of that water is from the automatic defrost cycle in the freezer,the water is supposed to run through a drain in the freezer but that drain is blocked so the water is draining into the refrigerator vents and ultimately to the catch basin instead of draining .
This tip i wrote will help ya to clear that drain in the freezer http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Samsung model#rs253basb side by side/ water pooling under vegi drawer & leaking out onto floor. water dispenser works when it wants too-not very often these days.
Leo Ponder
imufo2
Sep 15, 2011 | Frigidaire FRT15G4B Top Freezer...
Water filter on my side by side Samsung refrigerator is leaking. Leaving a small pool of water under the veggie drawer and then onto the floor outside the refrigerator
Well first thing shut the water off,drain water out by removing filter ,check the o-ring on filter and if you recently changed the filter you possibly pinched it when reinstalling and now you need a new. If not it could have a flat spot on it and wore out either way you need a new on.Appliance store (get model # or take with to match up) or even at times a hardware store that sells o-rings.
Mar 27, 2011 | Samsung RS2630SH Side by Side Refrigerator
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
Water is pooling, on the inside, at the bottom of the refrigerator, under the veggie/fruit drawers. After about 5 days, it spills out onto the floor.
hi , i can help you with that.
open the freezer back wall after taking all things from your freezer out.
on the bottom center of the freezer back wall there is a drain hole,
defrost all the ice with hair dryer and wipe it with a towel.
this hole should be free all the way to the drain pan next the compressor.
clean it with hot water and a pump...
thats all :) let me know if you need any more help...
Jan 11, 2010 | Refrigerators
Model # TBX18TRBR large puddling leak on floor, think has to do with defroster messing up?? A GE refrigator serial # HG539639
I've got the same fridge with the same problem (believe it or not it was manufactured in 1992 so it's a wonder it's still working).
I also have been able to narrow the problem down to a defrost issue. It appears as the coils are defrosted, the leaking water drains down through the inside of the fridge, pools in the bottom of the fridge (under the bottom drawers), then when that area is full it runs out onto the floor.
I'm still troubleshooting and will post back here within a week with my results.
Aug 22, 2009 | GE Refrigerators
Water comes from under drawers on fridge side, leaks onto floor
If leak continued then you must have a faulty cut off valve. Check and tighten valve. Also, check the hose that runs underneath the fridge for cuts or holes.
Jul 12, 2009 | GE Profile PFS22 33" Artica French Door...
Jun 07, 2008 | Frigidaire FRT15G4B Top Freezer...
Water pooling under my express thaw bin in bottom of refrigerator
no connection between lower drawer and water dispenser, however there is a water tank behind the crisper's storing water for the dispenser, its possible that there is a hole in the tank or a connection is leaking there and dripping water. remove all 3 crisper's and give a look at it. try getting water from dispenser while your checking (Might only leak when water dispenses
Mar 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRT15G4B Top Freezer Refrigerator Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
