Question about Canon PowerShot A460 Digital Camera
My A460 camera has a diffrent kind of problem which is while clicking a photo in a daylight or well lighted area the picture contains very light where i cant see anything and when i make veido it works fien can please some one tell me thatr whats wrong with my camera ?? is lance fine or that has got some serious problem
  • Canon Master
  • 4,738 Answers
First make sure that you're in full auto mode and not in manual or any of the special scene modes. Check your rotating mode dial that its set to the first red camera by the blue arrow.
If you already are and were in auto, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A460 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. Repeat as the fix recommends, but please note that there may be only a small hope that this will work as the shutter may be stuck in the open position. This is harder to get unstuck than a closed shutter.
Posted on Jun 04, 2009
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
I have Canon PowerShot A460 .When i capture a picture it look utterly bright both on Camera Screen and in PC. It flashes both in night mode and in day light or sun light. I 've reset all the functions...
I suspect that your shutter has stopped working. When you take the photos in good light, the shutter stays open causing total over exposure. I bet if you take a photo at night in a dimly lit place with flash, the photos would be fine as this does situation does not rely on the shutter.
Jul 24, 2011 | Canon PowerShot A460 Digital Camera
I downloaded the CD on my computer but my computer isn't finding the camera. so I am unable to download my pictures from the powershot A460.
You can download the photos directly using free picasa software's IMPORT tab.
Another method is to connect the camera Start.My Computer and you can see the camera as an external drive D: or E: Click on that and folders within until you see your photos. make sure to save extra copies of the enclosing photo folder.
Feb 17, 2011 | Canon PowerShot A460 Digital Camera
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
Daylight photos come with BLUE filter effect
Artificial light is a different colour than daylight. Our eyes compensate, so we don't notice it much. Most digital cameras can compensate too, but whether they do or not depends on the settings. The setting you want to investigate is color balance. If this is set to daylight, it will give an orange cast to pictures taken in tungsten lighting, and a greenish cast to pictures taken in flourescent light. If it is set to artificial light, pictures taken in daylight will have a bluish cast. The best setting for most people is Auto, if your camera has it. That will let your camera decide, and usually it will get it about right.
Nov 10, 2010 | Konica Minolta DiMAGE Z10 Digital Camera
My canon A-460 powershot
make sure it is not in Night mode.
Jul 26, 2010 | Canon PowerShot A460 Digital Camera
Light or white picture when shot on a broad daylight or on a well-lighted area
Are you in any other mode besides automatic when this happens. If you're not sure, check that the rotator dial is set to the first little red camera right next to the blue arrow (this is the automatic position). If you're in this position then it's unlikely that overexposure will occur unless you're also encountering mechanical failure of a stuck shutter.
May 27, 2009 | Canon PowerShot A460 Digital Camera
Camera takes white pictures in daylight
Sounds like over exposure due to the shutter not closing all the way. test video out. should work fine. shutter mechanism will need cleaning
Apr 25, 2009 | Canon PowerShot A630 Digital Camera
Canon PowerShot A460 Digital Camera Logo
192 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
