Hello,You can find the steps to use the scanner in the following links.http://www.scarborough.k12.me.us/high/tutorials/scanning/scanning.htmhttp://ced.ncsu.edu/seniorsurf/adv4/index.htmGood luck,~regards,Jegan
Take your scanner for a ride on your lunch & have a buddy look at cylinder misfire counts-- if you can use Mode #06 data on that system
Check fuel pressure on the road if that data is avail
Put a few parameters in the scanner & play them back when you return,put them up on a notebook or larger screen ,so you can layer them down a page together
Hi soji ... Corex Cardscan 60drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
you can download 3DP Chip v11.12 from Mediafire Open
it,and you will found Your driver like Example on the
screenshoot,and Click it,you will Redirect to the Driver you've need. Please don't forget to rate it if this helpfull.
Check your System scanner application is running. Open the End Task manager select the tab process and see there may be scanner.exe is there select that one and click end task.
If you know the brand and model, these can be used to search for the correct driver. The driver will need to be downloaded for the scanner to be recognized. I would suggest searching for the driver for the specific model.
Thumps Up!
