Question about Bosch Nexxt 500 Plus Dryer
Bosch dryer has pwr but not turning on
Bosch 500 plus dryer not turning on when start button is pressed, only a click.
  • 3 Answers
Unplug everything, remove the lid (only two screws) and check if the belt is still there around the middle of the drum. If the belt looks good then the problem is prolly the broken-belt electric switch that has tripped. That's described elsewhere here on Fixya. Did someone put in a mess of soaking wet clothes!?
Posted on Oct 09, 2011
  • 23 Answers
Sounds like the belt is broken or off of track.
Posted on Aug 15, 2009
How do you shut off the annoying Bosch Nexxt 500 Dryer wrinkle guard?
Click HERE to get the Users Manual for your machine, from what I can see, it's in the selection option of the machine.
From the manual:
Select the option to be changed with the "Menu" button. Press the button to move to the next option on the display. The active symbol starts flashing.
The current active option setting is displayed on the right. These settings can now be changed with the "Select" button. Press the button to jump to the next possible setting. Pressing the "Menu" button again saves the setting. If you don't press any buttons for 10 seconds the settings are saved automatically.
Hope this answers your question. Please rate and comment. Thank You
Joe
Sep 01, 2011 | Bosch Nexxt 500 Plus Dryer
Just installed new bosch dryer it works but no heat
htc activated. Unplug unit. turn unit around and take off back panel start at top you may not have to take completely off .You will see a thing looking like a thermostat press red button put cover back on and plug unit up. this should do it.
Aug 29, 2011 | Bosch Nexxt 500 Dryer
Dryer light and clicks but wont start...what could this be?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 25, 2010 | Bosch Nexxt 500 Plus Dryer
I have a Bosch 500 plus model. I was drying a blanket by itself when the dryer just shut off. The blanket was in a ball. I spread it out and turned the dryer back on and it wouldn't start. No error codes...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Oct 30, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer does not start
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jul 26, 2010 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 27, 2010 | Bosch Nexxt 500 Plus Dryer
The power goes on (lights up) and when I push start there is a click, but no movement. Can you help me?
wow, sorry. I shouldn't post til after more caffiene. I was thinking washer when I asked you those questions.
Now, the correct questions :) Have you tried on all cycles? When you press start does the display change at all? is the lint filter light on?
Apr 20, 2010 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 500 Plus Dryer Logo
558 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
