Question about Foxconn G33M Socket LGA775 motherboard
Sata drive cable positons on motherboard
Hello there, Im afraid I may have my drives ( 2 x HDs and 1 x DVD r/w ) connected to the wrong ports on my motherboard, ther are 4 ports and my system is a Advent T9609 with Intel dual Core Quad Q6600 processor.
Please can you tell me the correct order of the sata cables from drives to motherboard. many thanks in advance.
    President:
  • 1,179 Answers
The plug in sata ports do not matter for order unless you are plugging into ports reserved for RAID. Check your motherboard manual to see if any ports are reserved for this setup. If so change any cables out goint to those ports. You will also need to enter bios and make sure SATA is enabled in your settings. Once you have done this you should be able to boot and your drives will be auto detected. Hope this helps.
Posted on Jun 03, 2009
3rd SATA Hard drive can't detecte.
is the sata port activated in bios?
Feb 22, 2013 | Computers & Internet
How to connect DVD SATA to asus m4a88t-m motherboard
Hello you can download the manual here:
http://www.asus.com/Motherboards/AMD_AM3/M4A88TMUSB3/#download
Please select you windows system.
Open the manual folder and click on global for download.
Please unzip the file and you need adobe reader to read the content.
Basic connections is to plug the power cable (from power supply) in the drives and connect the HD sata cable to sata 0 or 1 and the dvd drive to sata 2 on the mainboard.This can not be done wrong because there is no jumpers to be set like the old IDE drive.
You just have to take antistatic precautions when working on the mainboard.
Here is some youtube video that shows you how:
http://www.youtube.com/results?search_query=how+to+connect+a+sata+hard+drive+&oq=connect+a+sata&gs_l=youtube.1.0.0i5l2.2651.12902.0.16537.16.13.1.2.2.0.100.886.12j1.13.0...0.0...1ac.1.DxJ-0V4vaJg
You also have to setup the boot settings for the drives in the bios.
In order to boot from the dvd drive and to make the installation.
Good luck
Dec 15, 2012 | Computers & Internet
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
I need to know where to plug in on motherboard
If its having sata connection you can see sata ports on *********** board using sata cable
1.Pic of sata cable
2.Pic of Sata ports on mother board
You can connect any one of the ports. and you need to go to bios and enable the sata ports if its not done already..
If you have a normal CD Drive you can connect with IDE cable.
See the pics below
Apr 24, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
How do i hookup sata dvd drive
You should have been supplied a SATA cable if you have bought a new DVD drive. On your motherboard you will see 2 orange connectors just underneath where the older IDE grey cables plug in. Thesae are you 2 SATA connectors. They will be labeled as 0 and 1, if you are not using of these at moment connect to SATA 1 incase you decide to hook up a SATA HDD drive at some stage. Power cable just plugs in as usual. If PC doesnt recognise the drive you will need to go into the bios ( press DEL or F2 at startup) and it will be listed under something like drive configuration and just enable SATA there.
Jan 20, 2010 | MSI 661FM2-LSR Motherboard
Sata dvd rom cause the computer to crash, is it because its plug in to the wrong plug in on the board or the sata on the motherboard isnt the right one im trying to install a sata rom on a gateway 5474,...
on pata ,flate data cable use in long connerter . on sata cable we use thin and flatcable join in n small squire port. some bord have both type port we can use diffrent port in same time . but port should be good. i think there no chance to join different connecter joining. we look seriously. in any coonater we saw cuttin g shape or male female shape. power cable of smps which join in hdd/cd room may be lose when we join any part it can be short so connecting any cable before we do switch off or pullout powercable.
Nov 05, 2009 | SuperMicro LiteOn SSC-2485K - Disk drive -...
When installing windows xp pro it does not pick up the sata drive
REVERSE THE CABLE, PUR IT TO THE CLOSIST CONNECTOR ON THE RIBBON CONNECTOR, GO IN BOIS SETTING TAB DOWN TO 1 DRIVE TAB THREW SETTINGS TO USER RETURN , INTER CYC HDS SECT
F10 SAVE CHANGE AND YES
REBOOT
ROD
Feb 05, 2009 | PC Chips M955G Motherboard
Foxconn G33M Socket LGA775 motherboard Logo
137 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
