Question about Sharp R-930AK Convection/Microwave Oven
Maytag MMV4205BAS stopped dead in the middle of a heating cycle. Unplugged and plugged back in. Oven is on the same fuse and it's fine. Any ideas?
    President:
  • 2,992 Answers
There are several possible causes for a dead oven. Since yours quit in the middle of heating, I'd say it's most likely failure of the magnetron tube which supplies the microwaves. There's a safety thermostat on the tube which opens up and shuts off power if the tube overheats. Overheating is one sign of a tube that's gone bad.
There's really nothing user-serviceable in a microwave oven. Because of hazardous voltages inside and the possibility of microwave leakage, service should be left to professionals. Take the oven to a service shop for an estimate.
Posted on Jun 04, 2009
    Problem Solver:
  • 6 Answers
Maytag microwave oven does not heat up using timer; works OK otherwise
If you wish to get some details microwave oven repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 18, 2016 | Maytag Microwave Ovens
Maytag microwave mmv4205bas key pad is not functioning properly
It could be that the buttons are worn out. You'd need to replace the keypad to fix it, which will likely cost about as much as a new microwave. See if you can get it fixed under warranty, also, try cycling the power, it's always worth a shot.
Aug 14, 2013 | Sharp R305KS Microwave Oven
Microwave oven is completely dead
i believe you would have to take the entire microwave caseing off to access the back of the plug
Jul 12, 2012 | KitchenAid KCMS2055SSS Microwave Oven
Maytag mmv4205bas
The problem is more than likely in the keypad control board, pricing on this part should be checked before going ahead with repairs.
Jun 29, 2012 | Maytag Appliances Over-the-Range Microwave...
MMV4205BAS no power. Was not using it.
Try checking the fuses under the button panel.
Jun 08, 2010 | Maytag MMV4205 Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
Maytag MMV4205BAS OTR microwave does not vent internal steam and the microwave shuts off. It takes about 15 minutes to reset and power back up. What part is bad?
I have this same microwave, and I'm having trouble with it shutting off. It use to go back on, but now it doesn't work at all. I tried replacing the two fuses under the panel, but that wasn't the problem.
After some research and calling vendors, I believe the issue is most likely due to a failure of the magnetron tube which supplies the microwaves. Take it to a repair professional to get a cost estimate on fixing.
This model of Maytag seems to have BIG problems! It's either the tube is out, the turner doesn't work, or it just goes dead. Usually it's after 2-4 years of service. Poor quality... Maytag lost a lot of clients with this product!
Apr 12, 2009 | Maytag MMV4205 Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
MAYTAG MMV4205BAS Running but not heating
If the food in the cooking compartment is not heating at all, then you may have one of several components related to microwave energy generation that have failed or became disconnected internally.
Magnetron Tube, HV Capacitor, Filament Transformer or any number of sensors that disable power to the system. The control board could also cause the system to noty function correctly.. You wanted general inputs.. there ya go.. LOL
Not sure I told you anything you didn't already know but you should ask the tech what he did after he gets it going...
Regards,
Rick
Nov 28, 2008 | Maytag MMV4205 Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
409 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
