Question about RIM BlackBerry Curve 8310 Smartphone
I cannot find device options so I can pair a bluetooth device - help!
    President:
  • RIM Master
  • 688 Answers
On your blackberry screen you may see only a few options,
press the option icon that has the blackberry dots logo
the you will see all your icons
go to the wrench which is your option settings and then to bluetooth
on blue tooth it will be blank, press the ball and add device
Posted on Jun 03, 2009
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Dec 28, 2013 | Sharper Image Portable Speaker System Dock...
HOW TO CONNECT AND PAIR BLUETOOTH ON CELLPHONES
In most cases you will need to enable your bluetooth on your phone. Then in the options their is a scan option or search.
The bluetooth device you wish to pair will have a button on it to put it into discover mode for a few seconds.
Please provide more details as to the type of phone and device you are wanting to pair if the above does not help.
Oct 13, 2013 | Computers & Internet
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
My samsung sgh-t139 cannot connect be found on bluetooth
To Turn Bluetooth On or Off
This option allows you to turn Bluetooth On or Off.
1. From Idle mode, press Menu ? Settings ? Bluetooth.
2. Make a selection and press the Select soft key or the OK button on your keypad.
My Devices
This option allows you to search for new Bluetooth devices. Highlight the Search new device option and press the Select soft key or the OK Button on your keypad. The phone searches for available devices.
Sometimes cell phones and bluetooth devices become problematic when trying to pair them together. If you've followed the directions correctly but are still not able to get them to pair, take them to your cellular company's store and let them pair the devices. They can show you step - by - step how to correctly do it.
Jan 26, 2011 | Samsung Cell Phones
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do i use the bluetooth facility in Acer Aspire 4715Z? What are the steps to be followed for enabling it? I would like to transfer data to and from my fone via bluetooth..i have a sony ericcson K790i...
just turn on the wifi or bluetooth switch in both device. after select the data which you want to send,right click > send > via bluetooth > search device > select the device > next > give pass word.. eg.0. > next> send>
in mobile you can see accept option. just select it,give pass word that you will give in your computer... eg.0 > and accept.
Mar 17, 2009 | Computers & Internet
RIM BlackBerry Curve 8310 Smartphone Logo
186 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
