Question about Avanti Washing Machines
I want buy avanti w789 v-belt (xqj41.16)
How can i buy that?
*avanti w797 v-belt (zxqb522.2-2)
Can i use above part insted of w789sa v-belt?
How much is it?
5 Suggested Answers
  • 3 Answers
SOURCE: Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Posted on Apr 20, 2008
  • 85 Answers
SOURCE: avanty w789SA
its the drainage problem .so either the drainer is getting blocked or the drainer is cracked and got faulty so needs to be replaced.
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Feb 26, 2009
  • 3741 Answers
SOURCE: My washing machine turns on but wont rinse my clothes
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Aug 20, 2009
KevinWhite
  • 1902 Answers
SOURCE: My avanti w797, suddenly stoped
Hello & Welcome to FixYa
E2 error means that the lid switch wont engage. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Apr 05, 2011
Model W797. Why won't tub spin or water empty?
it could be 1 or any number of things , starting with the control board /timer ,broken belt ,gearbox pump . a repairman might be your only course if help
Oct 01, 2015 | Avanti Washing Machines
Avanti w797 does not drain. impeller keeps falling off.
Go to the following link:
http://www.avantiproducts.com/products/id/489
at the bottom of the page, click on the pdf "parts and accessories"
Nov 24, 2013 | Avanti W797 12 lbs Top Load Washer - White
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
Wont spin or turn
It may be a bad belt. Check the spin bearing and the basket drive also. Both of these control the spinning of the machine. If you have a question, let me know. I am here to help you the best I can.
Feb 18, 2011 | Avanti W789SA Top Load Washer
WATER WONT FILL IN TUB BUT LEAKS OUT HOSES IN BACK OF MACHINE
Make sure the waste hose is sufficiently high enough above the ground to stop the water siphoning out. Try raising up the waste hose to approx 90cm / 36 inches.
Nov 10, 2009 | Avanti Top Load Washer W797
Avanty w789SA
Feb 26, 2009 | Avanti W789SA Top Load Washer
Avanti W789SA Water valve problem
Where do you live.I know some chenese guys who sell the spare parts.
Dec 14, 2008 | Avanti W789SA Top Load Washer
Nov 20, 2007 | Avanti Top Load Washer W797
Washing Machines Logo
158 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
