Quasar TP1020DH...need to go to channel 3 for conversion to digit
In order to use converter box I need channel 3 but the TV scans right past it....any suggestions?
Can you tune your television to channel 4? Most digital converter boxes have a slide switch on the back to select either CH3 or CH4. Select channel 4 on the slide switch and channel 4 on your TV.
Would you please let me know the type of antenna in connection you have on this TV? I have a viewer with an issue and I cannot find a users manual to view the back of the TV.
Thanks and good luck.
Posted on Jun 12, 2009
How do I get free local TV over-the-air stations?
The Quasar VV-2002 only has an NTSC (analog tuner). Very few stations with NTSC transmitters are still broadcasting. Only low-power stations were allowed to continue broadcasting an analog signal. Unless you are very close to one of the transmitters, your TV will not tune in the station.
You'll need to connect the TV to a digital-to-analog over the air converter box. (The low-end ones that were free or cheap with the government coupon are harder to find; a few models are still available.) These convert the ATSC (digital) signal to NTSC. Then use an appropriate antenna and follow the instructions to tune in the available OTA signals. Send these to the TV either on the RF or composite Line-in. Set the TV to the appropriate input and use the converter box to change channels.
I hope this helps.
(20" TVs weren't required to have an ATSC tuner until 2007. Since there are reviews for the VV-2002 from 2004, it obviously is an older set.)
Nov 19, 2015 | Quasar VV-2002 20 in. TV/VCR Combo
Good Afternoon, I have no cable where i live now, but i have a analog converter box, how do i install it to my tv to get local channels?
you install the cable wire into the box or antena into the box then the cable or rca cables into the tv. set the tv input to the right input (usually channel 2 or 3 for a cable) or input one for the rca cables then you need to hit the scan option on your converter box to scan for the channels and the tv to scan for the channels. please let me know if this works
Mar 14, 2011 | Televison & Video
Trying to hook up to digital converter box and cannot get the tv to see it? It won't let me in to set channels.
Check ur tv converter box a small button on the back of the converter box make sure it is not set to channel 4,make sure it set it to channel 3.Put ur tv on channel 3.Take the antena signal input put it in the converter box hole that call ANT.Take the wire that came with the converter box put the wire one side of it connected to the other hole into the converter that said OutPut.The other side of the wire should be connected to the hole in the tv said ANT hole.Now make sure ur tv converter box power a/c cord plug into the a/c power outlet and the power button is press on and have power to the converter box.The converter box now power LED light on indication should be on and it is green.Now the tv CRT screen picture should have a menu of the converter box funsctions.Just follow the on screen instructions and press the enter button on the remote and it will now auto scan for those free air Digital DTV channels.When the auto scan it reaches 100% is it done.Now u have done it.
Nov 12, 2010 | Curtis-Mathis Televison & Video
Can the tv pick up channels if we hook up a digital converter box to it?
Hi amber
To answer your question;
Yes, With the converter box you will select the channels and it will send it to your tv via channel 3 or audio/video cables.
Hope this help. goodbye and let me know if you have any question.
Mar 25, 2010 | Quasar SP-2721 27" TV
I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
Nov 18, 2009 | Sanyo DS27930 27" TV
Why can't I tune in new channels from set top box through vcr?
Sounds like you are trying to receive the new Over The Air OTA, digital ATSC signals on a VCR that can only receive analog NTSC, which are not sent by any but low-power channels. Did you miss the change over last April, postponed from Feb, and featured on every TV channel when you could have obtained 1 or 2 $40 coupons toward ATSC-to-NTSC converter boxes. Try www.dtv.gov for more info, IIRC.
If you are speaking of cable TV then see your company. These may be digital Quadrature Amplitude Modulation QAM signals that only certain TVs can decode provided they are not encrypted. Locals are never encrypted. This is separate from the ATSC conversion.
-Ken
Oct 04, 2009 | Quasar VHQ940 VHS VCR
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
Digital
Nope. Not a digital Television. I'm guessing it's an older one. Most TV's sold nowdays are Digital TV ready.
Jan 02, 2008 | RCA F32665 32" TV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
