Question about Sharp AL 1631 Copier
On my copies there is a 1/4 of an inch line of black toner powder down the whole left side. Inside the machine the toner powder is spilling out and getting everywhere. Now of course I'm out of toner
  • 54 Answers
Your fuser is shot. You will need to install a replacement fuser assembly.
Posted on Jun 03, 2009
    President:
  • Sharp Master
  • 1,447 Answers
It is the problem your fuser unite frashor roller change it or two scrow tight
Posted on Jun 16, 2009
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
Have a black line on all my scanned files, runs the length of the page, about 1 1/2 inches from the left edge.
To determine if the vertical lines appearing on your printed documents are related to a printing or scanning issue, print a test page by pressing MENU, 4 (Printer), 2 (Print Options), 3(Test Print) and COLOR START.
If the vertical lines appear on the Test Print continue to Procedure A:Cleaning the Corona Wires Inside the Drum.
If the vertical lines do NOT appear on the Test Print continue to Procedure B: Cleaning the Scanner Glass.
Procedure A: Cleaning the Corona Wires Inside the Drum:
NOTE: Brother strongly recommends that customers do not use generic drumunits and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
A1. Power off the Brother machine using the power switch located on the right side of the machine.
A2. Press down on the front cover release lever and open the front coverby pulling it towards you.
A3. Hold the green handle of the drum unit (labeled 1). Lift the drum unit up and then pull it out until it stops.
NOTE: If you cannot pull the drum unit out, make sure that the front cover is fully open.
A4. Remove the toner cartridges one at a time, by holding the handle of the cartridge and lifting it up and out of the drum unit.
Note: We recommend you place the toner cartridge(s) on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
A5. Lift the white plastic corona wire cover by lifting the tabs locatedon the right and left side of the cover.
A6. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right several times.
Note: Be sure to return the tab to the home position. If you do not, printed pages may have a vertical stripe.
A7. Close the corona wire cover.
A8. Repeat Steps 5 through 7 to clean each of the remaining three coronawires.
A9. Reinstall the toner cartridge(s):
NOTE: Before reinstalling the toner cartridge, shake the toner cartridgeside to side.
Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum. Fold down the toner cartridge handle once the toner cartridge is in place. Repeat this for all the toner cartridges.
A10. Push the drum unit back into the machine until it clicks into place.
A11. Close the front door and power on the Brother machine.
A12. Print a test page by pressing Menu, 4 (Printer), 2 (Print Options),3(Test Print) and Color Start.
B1. For safety reasons, power the Brother machine Off using the power switch located on the right side of the machine.
B2. Lift the Document Cover and clean the following with a lint-free cloth moistened with a non-flammable glass cleaner:
a. Run your fingertip over the scanner glass of the flat bed to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris. (Caution! Do notpress down on the glass very hard.)
b. Run your fingertip over the scanner glass on the left to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris.
c. The white plastic pad located on the underside of the Document Cover
d. The white plastic pressure bar located to the left of the white plastic pad.
B3. Close the Document Cover.
B4. Test the machine by making a copy of a blank sheet of paper using the ADF (Automatic Document Feeder) and a copy using the Flat Bed.
a. To make a copy using the ADF, place the document face UP in the ADF, press the COPY mode key located below the LCD display and then COLOR START. If the problem continues,repeat Steps 2b and 2d at least 3 additional times.
b. To make a copy using the flat bed, lift the Document Cover of the flat bed, place the document face down on the scanner glass (make sure the ADF is empty) and close the Document Cover. Press the COPY mode key located below the LCD display and then COLOR START. If the problem continues, repeat Steps 2a and 2c at least 3 additional times.
Oct 29, 2010 | Brother MFC-9440CN Laser Printer
Black line down left side of sheet, if i'm copying a page that is and i can't get rid of it no matter what i try i've changed the drum and the toner and still get a line down the whole sheet
If the received fax's are ok and there is no line; and you only get the line when you make a copy....I assume the people you send to are also getting the black line down the page,?? then the problem is in the optics...favorite is some kind of dirt, glue, or corrector fluid on the glass that the original passes over when you make the copy.
Aug 20, 2010 | Office Equipment & Supplies
On left hand side of page horizontal line
You might have touched the main charger cleaner a green part above the waste toner container. just push it inside and try to copy and print
May 11, 2010 | Copystar Office Equipment & Supplies
Copy and faxes come out with a black line on the left side about an inch from the side.
If your INCOMING faxes have the same black line as your copies then the problem lies in the toner cartridge. A line on OUTGOING faxes and copies would suggest something on the scanner glass. This is a small strip of glass under the cover where your originals are fed into. Another way of testing is to run a report from the operation panel. If a report generated from the machine is ok then it is the scanner glass. If the report has a line then it is in the toner cartridge.
Good Luck
Feb 20, 2010 | Canon FAXPHONE L80 Laser
Black line down middle of confirmation copy
You need to remove the toner cartridge if fitted pull out the toner holder, making sure the opening is on the top, if not the toner will spill out, set this to one side and clean the toner holder thoroughly.
Mar 18, 2009 | Office Equipment & Supplies
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Printing vertical grayish black ink on the left and right side of page
replace the toner cartridge, you wont have anything "dripping" out of it as the toner inside is a powder. if it still appears replace the fuser.
Oct 22, 2008 | HP LaserJet 4250dtn Printer
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Sharp AL 1631 Copier Logo
137 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
