Question about Coleman Mach 15 Air Conditioner
Coleman mach chill grill - heat turns on whether we have it programed or not. have heat off, ''I feel'' off, can be 80 outside we can be gone and come back to 110 degrees inside and heater on. When it comes on by itself has a ticking noise in ceiling compartment. Only way we can gaurantee that it will not come on is to turn off propane. This is on our 2004 32 ft Everest 5th wheel.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Sounds like you have a bad thermostat or a short in the wiring. The clicking that you are hearing in the ceiling is a relay in the control board. When this happens, remove the face plate from the thermostat and check for 12VDC between the Blue and the White wires. If there is power then you have a bad thermostat. If there is not power there, then the problem is elsewhere. However, it sounds as if you have a bad thermostat.
Posted on Jul 04, 2009
I have a Coleman mach 3 ac unit. ive replaced everything except the compressor. the fan will come on but when i put it on ac it blows the fuse in the thermostat.
Fuse in the tstat?? First inspect the low voltage wire outside for imperfections, such as bare wires. Unhook the low voltage wires to condenser outside and cap with existing wire nuts. Then replace fuse and turn system on with cooling. If fuse still good then you have a short in the contactor coil in the condenser. Need new contactor. If fuse only blows when a call for cooling it's in the wire for low voltage or the contactor itself.
May 21, 2017 | Coleman Heating & Cooling
Why is campers inn saying I need to replace my Coleman Mach 3 with a Coleman Mach 8?
we would have no idea . perhaps if you contact Coleman they can tell you .
Feb 15, 2017 | Coleman Heating & Cooling
Coleman mach 8333a871 - I think my start capacitor has gone out. How do I check it, and can I replace it?
You can check with a multimeter that has a micro Farad checker you can read on the cap what the mF is and what the range will be plus or minus a certain percent. You can change it just remember how you took the wires off. example 80mf cap plus or minus 10 percent would be72-80 would be good cap.
Aug 01, 2011 | Coleman Mach III Air Conditioner
Coleman propane stove, tank got very cold. why?
as propane is used it can create frost on the tank or just cause the tank to feel cold. this is normal. this will be worse when the tank is almost empty.
May 28, 2010 | Coleman Propane Grill Stove 9921-700
Fan is not blowing cold air
Sounds like the freon is gone in the system. These small system will lose freon and then you get air and nothing else
Feb 12, 2009 | Coleman Mach 15 Air Conditioner
Problem with heat pump
This sounds like a 4--step furnace. Step 1 ,the small ven fan turns on and proves it turnning thru the small air tube that sucks a switch close . Step 2 the spark igniter lights the pilot ...Step 3, the main gas valve opens up and dump gas in the venture tubes to heat the box up, Step 4 theres a swith in the box the when heated closes and turn the fan on! Thank-you-very-much!
Aug 18, 2008 | Coleman Mach III Air Conditioner
Air conditioner and heater come on by itself
Has anything been changed since it last worked well or normal? Thermostat ?
Aug 04, 2008 | Coleman Mach III Air Conditioner
Coleman Mach 15 Air Conditioner Logo
321 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
