Question about Cooktops
Crack on the corner - we have a run on the ceramic
We have a crack on the corner - we have a run on the ceramic cooktop but it runs from one corner to another(same corner - about 90 degree shape) - does not affect the burner area - is there a special type of epoxy or glue that we can glue the pieces back - I've been gone for a few months and came home to this chip problem - thank you for your help - do i need to replace the ceramic cooktop portion of the JED8430ADW?
Glass on cooktops are not fixable - due to the chance of electrical shocks the manufacturer strongly suggest replacement of the glass.
Posted on Jun 04, 2009
Clipped and now cracking ceramic cooktop
Sorry to read about your problem, I hope this helps you out.
you may want to think about a new unit, the glass replacement will cost from $600.00 to $900.000
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 18, 2010 | KitchenAid 32 in. KECC508 Electric Cooktop
The top of my halogen hob has cracked from top to bottom thro the centre is there any way of repairing it? it is a 5 ring creda rangemaster
you cant repair the glass but you can get the ceramic glass as a spare part. you will need the exact model number to get the correct part once done your hob looks brand new. if cracked through one of the zones you could chack there is no damage to element or themal cutout running across the centre of the element before proceeding.
Aug 22, 2010 | Cooktops
My ceramic cooktop has cracked. Can I just order
You can get the main glass top, the part number is WB62T10525 and it runs just under $300.00, it is shown here as 51. It does take a bit of dis assembly to install it.
May 05, 2010 | GE Cooktops
Want to vent gas cooktop from top of ceiling cabinet down to basement and out chimmney. Distance is approximately 20 feet with four 90 degree angles. Suggestions? Thank you.
There are special fans that are used for this. Use the web to look up exhaust fans. Normally used for boilers, tumble dryers where the distance required to run is further than the fan supplied with the item can push it. The fan will need to be wired in so that the gas cannot be turned on until the fan is running. Pick the fan that best matches flue diameter, temp, and distance
Oct 04, 2009 | Cooktops
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Is there some way to repair a small crack in a ceramic cook top without having to replace the unit?
you can replace the cooktop but this might cost you about the same if you just went and bought a new one
Jun 07, 2009 | Jenn-Air JED8430 Electric Cooktop
I have a whirlpool drop in ceramic stove and a burner isnt working. i had a repair man come and he was trying to pry the stove up but was having trouble because the person that insatlled it years ago...
When you dont replace the ceramic top that ios cracked could cause issues in your circuit board. The best thing t do is buy a new stove. The parts nad labor along is going to cost you about the same price as a new one.
Apr 25, 2009 | Stoves 23 in. Premier TC600I Electric...
Crack on glass top
usually not, I have heard of them cracking with extreme temp changes. like burner on high, some one puts a frozen turkey down not knowing and crack
Jan 26, 2009 | Jenn-Air JED8430 Electric Cooktop
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
How to fix a crack in ceramic top
Mine cracked and I ordered a replacement shipped overnight. I can't get a repair person out before Christmas. Is it easy to do it myself?
Nov 18, 2007 | Whirlpool GJC3034 Electric Cooktop
Cooktops Logo
577 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
