Question about Garmin StreetPilot c340 GPS Receiver
My Garmin StreetPilot c340 is frozen.
I tried to turn off my GPS unit and nothing happens. The off switch does not work. It is stuck on the Where to screen, view map, etc. The unit is just over a year old.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Posted on Jun 10, 2009
After you reset your Garmin, if it still does not work, you should reset your settings to factory default. You can do this where you see the little wrench icon.
Posted on Jun 06, 2009
    President:
  • 1,486 Answers
Press and hold the reset button on the side.Will be ok then.
Posted on Jun 03, 2009
I ran the battery dead on my c340 GPS Now
You will have to open up you unit, and replacing the battery, you can get them from Garmin.
May 08, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 frozen in on position does not turn off when power is pushed stuck on arrival time
Look on the back or on the side someplace, what you are looking for is a small hole, just a little bigger then a paperclip. This should be the reset button, hit that with said paperclip and then allow the system to reboot. This should clear up the problem.
Mar 12, 2010 | Garmin StreetPilot c340 GPS Receiver
I used the Garmin Web Updater download to update software on my Garmin StreetPilot C340 GPS and it now indicates that I am in Olathe KS...I am in ND. How do I fix that?
Have you been outside with the unit since the update? Usually when you take the unit outside and turn it on, it reads the satellites and gets it's location from those.
Feb 01, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin c340 will no longer connect to satellite
Hi
Try updating at Garmin Here
This can resolve sat problems
Regards.
Apr 15, 2009 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not power on - even with soft reset
well after being on hold with garmin for 32 minutes they told me to send them the unit back and will repair at no cost.
My unit was purchased on may 27th 2007.
Jul 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Screen frozen
Be aware - A Master Reset WILL ERASE ALL OF YOUR FAVORITES. To do this, turn the unit off. Press and hold the bottom right side of the screen and turn the unit on.Keep pressing the screen until the unit asks if you want to reset. Press yes. This will do the Master Reset.
Mar 30, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
475 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
