Question about Dell 962 Photo All-In-One InkJet Printer
Printer error 0x0000007e - Dell 962 Photo All-In-One InkJet Printer
    Scholar:
  • 156 Answers
SOLUTION:
At this time, the only way to add the printer from Print2PDF Server Edition to a Windows Vista client machine is as follows:
  1. Share the following folder on the server as print2pdf_files with read access:
    %SystemRoot%\system32\spool\drivers\print2pdf\
  2. Run the following batch file on the client (replace servername with the name of your server):
Posted on Jun 03, 2009
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Error blue screen when installing
http://www.wiki-errors.com/wiki-errors.php?wiki=0x0000007e I hope this helps :)
Oct 11, 2013 | Dell Dimension Computers & Internet
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Windows cannot connect to printer. Operation failed with error 0x0000007e.
This problem happens when you are trying to share printer between 32 bit (x86) and 64 bit (x64) Windows. The 32 bit driver not compatible for 64 bit operating system. At this situation you may get error message like this "Windows cannot connect to the printer Operation failed with error 0x0000007e".
But there is an alternate way to add printer from 32 bit Windows to 64 bit Windows.
Start >> Devices and Printers >>
Then Add Printer with the help of IP address of 32 bit Windows computer.
Detailed steps with screen shots are given in the following link.
[Solved] Operation failed with error 0x0000007e
Solved Operation failed with error 0x0000007e Share printer between 32...
Apr 11, 2012 | Xerox Office Equipment & Supplies
Error code Stop: 0x0000007E
General Memory dump failure, least thats what I kinda get from the Error that you have displayed. This actually happens for quite a few reasons. Over heating, video graphics error, CPU failure (over heating), or something wrong with a prime system failure in a file. Most of time time on labtops it would be with the overheating, or not enough ram to run the processes that are active. Use Msconfig and under the startup tab turn off what you not need during start up. Also make sure you have the Labtop mounted and the legs are down, letting air access to the bottom of it to help with cooling. Also on the back and sides there should be exhaust vents, used compressed air to clean them out and make sure nothing is restricting them.
DrakeTech
Dec 29, 2009 | Sony VAIO VGN-NR160ET Notebook
Error code 53000:031e stop:0x0000007E COMPUTER WIIL NOT BOOT UP
hi there !
-boot to SAFE MODE
-restart the computer and press F8 and choose SAFE MODE then do the steps below
Windows Update Causing STOP Error 0x0000007E
-For now simple system restore should fix the issue, else uninstall this update by booting to safe mode.
-Uninstalling windows update KB973879 and hiding this update from available update is currently seem to be fixing the issue.
In case if removing update KB973879 doesn’t fix the issue, we need to remove remaining two updates KB970653 and KB972036.
cheers!
Oct 20, 2009 | Dell Latitude D510 Notebook
Stop: 0x0000007e
Upgrade to vista or windows 7, Xp is not supported by microsoft anymore (BUMMER)
Sep 30, 2009 | Microsoft Windows XP Home Edition
Printer installed fine, won't print. Error code 0x0000007e?????
Maybe you didn't configure the port.
To do this you must go to properties of the printer then try to locate the port output. LPT1, LPT2... the default value is LPT1.
May 17, 2009 | Lexmark X7170 All-In-One InkJet Printer
Balance - Blue Screen during shut down stop error 0X0000007E
check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
May 11, 2009 | Computers & Internet
0x0000007e error code in acer motherboard of win
hi,
Some users experienced similar problems when SP2 was released, so this could be the problem. If the user sees a stop error code of 0x0000007e, this first issue is likely the reason why the computer does not boot properly.
The second issue will only occur on systems with certain acer motherboards. This error manifests itself with an error code of STOP: 0x000000A5. It is unknown how to fix this problem other than by installing a USB storage device, or even possibly removing a USB mouse and replacing it with a PS/2 port compatible version.
If that is not enough, Microsoft MVP Jesper Johansson reports that there seems to be a third, less common problem with SP3 computers, this time on Intel. Some may receive a 0x00000024 stop error, which he believes may be due to an issue with either the NTFS file system being corrupted, or a faulty video driver.
go to microsoft .com under solutions page and type in the information code error they have been working on a dowload patch to correct this . go there http://support.microsoft.com.
Mar 30, 2009 | Acer Computers & Internet
Dell 962 Photo All-In-One InkJet Printer Logo
1,610 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
