Washer fills, agitates, but does not drain or spin. Checked all hoses for obstruction, nothing found, water drains out upon removing drain hose from back of unit. nothing in pump....checked both ends. pump wheel seems to turn. can hear timer clicking to switch cycles
Check the following to address the issue--
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain
hose connected to the pump (pump is usually located at the bottom
and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the
water pump such as a frozen pulley or a broken impeller. If that's
the case replace the water pump. Note: if you have a belt driven
washer, check the belt(s) for cracks, as this would be a perfect
time to replace the belt(s) if needed.
