Question about Kingston 4GB Secure Digital High Capacity Memory Card
Hi ,i having 1GB of flash drive of Transcend company.for some unknown reason that showing "write protected ,disable it to use" message is coming.i tried several ways but not succeeded.how to disable that write protected flash drive.presently it allows to copy from the drive but not to that drive and not also accepting the deleting or formatting the drive.how to overcome the problem. thanks for any help.
I reset my phone setting.after start my phone my transcend memory also locked?what can i do?pls help me
Posted on Apr 19, 2012
    Scholar:
  • 72 Answers
I sense that your usb memory is equipped with a physical write protect switch that you may have overlooked. Locate it, switch to the "non-writeprotected" (unlocked) mode and everything should work normally. Good luck!
Posted on Jun 03, 2009
  • Håkan Sterner Jun 05, 2009
    Ok, so there isn't a mechanical write protect switch on your SD card as I thought. That would have explained everything but if you say your card has no such switch then I understand this is not helpful to you.
    Maybe you could increase chances of an answer that helps you if you specify the exact model number of your SD card.
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have 8 gb trancend pen drive and it is showing
This can be simply removed by changing the position of the write protect lock on the pen drive body. Please refer the figure.
Please come back and rate my solution if turns to be helpful for you or also if you need more clarification. Thnx :)
Apr 07, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When I plug my 4gb flash it say malfunction and not recognize
have you tried putting it in a different usb port if you tried that try updating your computers usb drivers from the support site for the computer your trying to use the flash drives on
May 28, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend jet flash showing write protected message
hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
Jan 30, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 2GB Flash Drive
Most of the flash drives that I have bought had a limited lifetime warranty.
Most of these devices require a driver. XP and Vista come with the popular drivers pre-installed.
Have you investigated the requirement for a driver?
Transcend Downloads:
http://www.transcend.nl/Support/DLCenter/index.asp
Transcent Tech Support:
http://www.transcend.nl/Contact/CuTechsupport.asp
I don't know about the laws where you are, but where I am located there is something called "Consumer Protection". If the dealer is a retailer, he is supposed to give you a refund, or a replacement.
I would get in touch with Transcend and complain about the dealer. Then I would put in a formal complaint to the consumer protection about the dealer.
You can email Transcent:
Service@transcend.com.tw
In the documentation that came with the device, there must be some warranty policy information.
Transcend USB Flash FAQ:
http://www.transcend.nl/Support/FAQ/index.asp?axn=queryFAQ&srhWhatBU=PBU&Func1No=10&LangNo=0&FldNo=18
Jerry G.
May 29, 2008 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Kingston 4GB Secure Digital High Capacity Memory Card Logo
151 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
