Question about GE Nautilus 24" Built-in Dishwasher
Ge nuatilus wont drain - GE Nautilus 24" Built-in Dishwasher
  • 6,784 Answers
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer or control board
Replace if defective (note: uncommon problem).
Posted on Sep 16, 2009
I have a ge profile washer machine washes and spins but wont drain
Hi.
Disconnect power, then locate the access to drain pump. On GE top loader the pump access is usually at the back, sometimes at the bottom. Disconnect the hose from the pump and remove any blockage in there.
Check also the height of the drain hose at the back and ensure that the hose is set according to manual. An drain hose set incorrectly will result in drain problems.
If that does not fix the problem, clean or replace the pressure switch and pressure hose that detects water level determining when to start and stop draining.
Regards.
Ginko
Jul 08, 2011 | GE Profile WPRE8100G
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Ge profile dishwasher wont drain. i have already replaced the drain motor. Why wont it drain completely
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 12, 2010 | GE Dishwashers
Water wont drain
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 12, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Wont drain
1)block in the drain hose.(check the hose of tank to drain connection)
2)problem in the drain pump.
Jan 08, 2010 | GE 24 in. Profile PDW7800 Built-in...
Ge spacemaker spins but wont drain
first check your hose make sure it not pinched... next you can check the coin trap...its at the back where the drain hose goes in the machine.... turn it and pull it out ... make sure you have something to catch the water....if this do not help you may need a new drain pump... let me know
Sep 22, 2009 | GE Washing Machines
I have a ge hydrowave top load washer. it wont drain...any suggestions?
Check the filter on the drain pipe and clear any muck accumulated there and also check that the drain valve is working or not. A thorough cleaning should solve the problem...............................sodeep
Jul 31, 2009 | GE Washing Machines
My top loading GE washer wont drain, just makes a loud noise
Plug off the mains. You have to dismantle your pump to examine if there is a block in there. Refit carefully. Just in case.......
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Mar 17, 2009 | GE WBSR3140DW Top Load Washer
Ge nautilus/dw
it sounds like your dw wont drain. check air gap cap on sink, if there. then drain blocks.
Dec 24, 2008 | GE Nautilus 24" Built-in Dishwasher
My ge nautilus dishwasher won't drain can you help?
gsd4200joobb dishwasher ge wont drain i can feel the hoses pumping water not going out thou and garbage disposal clear
Aug 25, 2008 | Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
249 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
