Question about Sharp R-403HW Microwave Oven
Sharp R403 microwave internal electrical short/fire
I bought a Sharp R 403 JKF in 06. I have the same problem as the other person. When I turned the oven on it sparked and smoked a bit at the waveguide cover. It burnt a hole in the cover. II unplugged it and have not used it since. Has anyone determined if the Sharp microwaves have been recalled? Definitely my replacement microwave will not be a Sharp unless they make good on this factory defective unit. PITA
  • Sharp Master
  • 9,098 Answers
This is a simple problem & solution.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Since your waveguide cover is damaged, it will need to be replaced. It provides important protection for the magnetron.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 04, 2009
  • peggy99 Oct 18, 2011
    Just had the same issue...Sharp got me a replacement cover within 20 hours of my call!! Will make sure to wipe down the darn thing every time!! That should be in BOLD letters on page one of the owners manual.
  • Lee Waterrs Camp
    Lee Waterrs Camp Dec 12, 2016
    Forget wiping it down, damn thing almost caused a fire at home. Ironically, it replaced the 20 year old microwave I lost in housefire only 11 months before. My answer, don't buy a Sharp
Heat: I placed a microwavable food product in my sharp carousel r-1505. there was a tiny piece of the foil still attached to the rim of the product container. upon start, the foil immediately caught...
Maybe. The presence of metallic material (foil, stainless steel silverware, etc.) in an operating microwave oven creates electric arcs between the foil and the inside wall of the oven. And this can destroy the electric components.
Sep 22, 2013 | Sharp R-1505 Microwave Oven
Sharp R-520 JKF
No! The problem is one or two bad door switches, or possibily the keypad control board.
Apr 11, 2012 | Sharp Microwave Ovens
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Microwave blows fuse when turn on
If it is blowing an internal fuse it could be a lot of things.
-short in the motor
-short in one of the other components
- gunk/dust could be causing a short
If it is your house circuit breaker/fuse then either the microwave draws too much current/amps for the circuit and you should try another circuit or you already have too many things/appliances plugged into the same circuit (not necessarily the same outlet) and need to unplug one or more of them so that the 'fuse' doesn't blow.
Kugellager
Nov 07, 2009 | Sharp R-1460 Microwave Oven
Boiling water caused large "Pop" sound/microwave not working now
I would guess that the boiling water may not have been the cause ...
If you are lucky ... try this first:
Unplug or turn the circuit breaker off (if it is a built in unit). Wait an hour and then repower.
Odds are that will not clear things up ... but it is easy to try. Probably one of the electronic internals broke.
A number of different internal component problems could cause this heating failure in the microwave. It could be the magnetron, the high voltage transformer, the PC board, the diode, and the capacitor. This type of problem will need to be diagnosed and repaired by a service technician. Microwaves are inherently dangerous to service. This type of repair is not something that you want to try to do yourself. Internal capacitors in the microwave can retain a lethal electrical charge even when the microwave is completely unplugged. A microwave radiation leakage test should be performed on the unit using proper testing equipment following any internal component repair.
Jan 25, 2018 | Sharp R-1480 Microwave Oven
Microwave shorting
Good Morning Greenapple,
I would need more info to tell you if you have 'solved' the problem(s).
I will tell you that ALL parts should be back in place, correctly installed.
You should STOP using the microwave until you VERIFY what caused the problem and that it will not reoccur and all parts you removed are reinstalled.
No hot cuppa tea or bowl of soup is worth a house fire caused by an electrical malfunction.
Personal injury from an electrical flash burn or the possibility of radiation damage to your body also are not worth the risk. Get a new microwave if you cannot resolve with certainty.
Larry Hanson EH&S Specialist,HVAC/R Tech 30 years plus in Electrical and Electronic troubeshooting
Apr 04, 2009 | GE JES1238 Microwave Oven
Microwave problem or electricity circuit problem?
It sounds like there is too much running off that one power line in the house... its starving for power which will take from where it can such as UPS fridge or freezer - other than that it could be a faulty junction box or wiring so you would probably want to see an electrician about it before there is a fire... If too much power is sucked from one wire it may get very hot!
May 05, 2017 | Sharp R-320H Microwave Oven
Daewoo kor-861h, electrical smell and will not heat.
Turn if off, and leave it alone, remove it, if you can remove the unit, take it in for service, something is wrong if you smell electrical, most people for some reason can smell and identify correctly electrical or at least insulation burning smells, which means something is burning internally, not safe, fire hazard, unit needs to be repaired by qualified technician or replaced with new unit, take no chances, nothing you can do to repair this, could be a shorting transformer, or shorting power cables, but to attempt to trouble shoot this with email is a long shot, and depends on your experience expertize and testing equipment.
I wish I could give you a short easy answer, but the hazard and your safety is more important than a microwave.
Will
Nov 30, 2008 | Daewoo KOR-860A Microwave Oven
Sharps microwave
The door switches go bad...little micro-switches. Check them for switching on and off. Some are closed when the door is open, some are open when the door is open. It could even be that the catch has moved out of adjustment. If that isn't the problem, you have to consider the brain board which is usually so expensive that the microwave is not worth fixing.
May 12, 2008 | Sharp R-510HW Microwave Oven
Sharp R-403HW Microwave Oven Logo
780 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
