Question about Kenmore Refrigerators
Kenmore side by side refrigerator - fan scrolls?
Folks,
I have kenmore side by side refrigerator model# 106.59599993. I was cleaning the coils and noticed the following.
The fan in the back, seems to have able to scroll forward and back a little. Is this normal? My inlaws have a similar model one (2 years newer), and their fan does not seem to have a scroll.
Normally, when there is a fan i was thinking that it would NOT have scroll like the hvac units and car ones.
Pl advice,
the dr
  • 447 Answers
SOURCE: Hotpoint refrigerator not cold
There is a defrost timer that initates defrost for 30mins every 8hours of compressor run time. Take off the thermostat knob and the freezer damper knob, remove light guard. To the right of the thermostat, is the timer advancement screw it is small,and it looks like a plastic cam not a screw. you put the flat blade of a screwdriver and rotate click by click till unit shuts off (you will hear louder click and fans and comp will shut off. Now its in defrost. Wait 5mins open freezer remove lower bin look at drain hole where frost buils you shoud see the heater glowing red melting the frost. If no red glow and no heat from panel. You must go further with the diagnosis.. A solved rating will keep this expert advice coming...........
Posted on Oct 03, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
SOURCE: kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Posted on Feb 19, 2008
SOURCE: Kenmore Refrigerator Model #596.76522500
Where is the motor,Evaporator fan locate at?
Thanks,
Ko Ko
Posted on Jun 16, 2008
  • 161 Answers
SOURCE: Replaced Start Relay because it was clicking...now?
If you are sure you have the right start relay, and are positive the start and run connections are correct, the compressor may be bad. There is an internal overload/overheat thermostat inside the compressor. If the motor windings are partially shorted out it will run for a little bit then stop. It will probably start after several hours when cooled down. The other possibility is that you have the start and run terminals reversed. If the start winding can't kick out after a few minutes it will overheat. As a final test, disconnect all wires from compressor. Plug in the box and turn it on. Make a test cord with a plug, wire and some alligator clips. One clip on one side and two clips on the other pole. Single clip goes to the common terminal, One of the other goes to the run. The last one is briefly touched to the run terminal. Just keep it there long enough for the compressor to start then remove it. Let it run for a few hours. It should cool the box down completely. It will run until you stop it as it's not using the thermostat in the box. If it works this way replace the relay again. If it stops by itself the compressor needs to be replaced. This is almost never worth it to fix.
Posted on Jul 03, 2008
Evaporator fan
Usually the fan is automatically turned on when needed. Good job on cleaning the coils; number one issue with refrigerators.
Oct 29, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
What year was model number 253. 54622402 built? Freezer is not getting cold enough is it worth fixing?
can;t help with sears model # for age but do ck the model # plate for the type of coolent like R 12 or R 134 / if its 12 i would replace frig .. the poor cooling on any frig may be caused by dirty coils or fan motor blowing over the coils . clean them and ck that fan is going . ther is also a fan in freezer that may have quit so ck that one also . mm hope this helps .. feeed back pls .. mm
Sep 18, 2011 | Kenmore Side by Side Refrigerator
Fan motor keeps kicking on.
You must have a bad compressor relay
Dec 22, 2009 | Refrigerators
Kenmore side by side, fan on, lights on, compressor hot, no cool.
You probably have a bad overload/relay on the compressor . The piece which plugs onto the compressor . Or a bad fan which cools the compressor (condensor fan motor ). Also check the coils to make sure they are clean . Would need the first 3 numbers before the ones you gave , to be able to give you the part number for the o/r .
Jul 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite Bottom Freezer Refrigerator Model 795.7554
the condenser coil on this is located in the back side and removal of the rear cover is need to get to the coil. It's on the right side looking at the back. make sure to unplug the ref before taking the back off.
Aug 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side by side refrigerator model 106.56532400
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Dec 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
