How do I correctly order a new fan control board for my HVAC
I have an Armstron Air fan and furnnace that is 15 yrs old, 5yrs ago I added AC with the pump residing outside. I turned the AC on the other day only to find out that I had a problem. Nothing happened when I fliped the unit on. Not wanting to spend any more money than I have to I'd like to fix the unit myself. I've already determined that the fan works in both high and low speed, the fan's runing while I figure out my next move.
I belive I need to order a new fan control board; Can you assit me in determining the correct model?
  • 614 Answers
You have two wires going outside they should be hooked to Y and C on the control board. If you have a meter check betweenY and C. If you have 24 volts your problem is outside. If your unit has a low pressure control it may be low on gas meaning a leak. Rusty
Posted on Jun 05, 2009
Olds bravada only blows hot air
Is yours manual or Automatic HVAC system ? heating ventilation air conditioning . When is the last time you tried it ? did it work then , last year ? Where do you live south , north ? Have you had any refrigerant added lately ?
The Heating, Ventilation and Air Conditioning (HVAC) system is divided into three separate sections. The first, Heating, Ventilation and Air Conditioning, has all procedures that pertain to a HVAC component or function that is not specifically associated with the manual control system. The second, HVAC Systems-Manual, has all procedures specific to the manual control system.
Begin the system diagnosis with the:
Symptoms - HVAC Systems - Manual in HVAC Systems-Manual for 4.3 L without DTCs
Diagnostic System Check - HVAC Systems - Manual in HVAC Systems-Manual for 2.2 L with DTCs
Diagnostic System Check - HVAC Systems - Automatic in HVAC Systems-Automatic for 4.3 L with DTCs
The Diagnostic System Check will provide the identification of the control module(s) which command the system.
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
Review the Description and Operation information to help you determine the correct symptom diagnostic procedure when a malfunction exists. Reviewing the Description and Operation information will also help you determine if the condition described by the customer is normal operation.
Apr 13, 2015 | 2001 Oldsmobile Bravada
Split system AC has pungent brussel sprout odor
clean well all the small drainage with bleaching liquid and soap it with scented soap.also at the back of the unit that are having small drainage and through the drain hose
Apr 17, 2014 | Coleman Heating & Cooling
Won't change from fan mode
you more than likely need a new control board or front display control board
Aug 09, 2013 | Haier Heating & Cooling
No cool air coming out of home air conditioner
Unless your compressor is burnt up, you probably don't need a new unit. If it's a 1998 it's not that old and you can get parts, the only thing is it's probably R-22 refrigerant and they must fix the leak in the unit if that's the problem before adding refrigerant and the refrigerant is expensive.. All they have in a heating and cooling system, that needs replaced, are a few parts. Outdoor unit has a fan motor,compressor, capacitors fan and compressor and a contactor. Furnace has a blower motor, capacitor, gas valve, fan and limit or furnace control board, which they still make replacement parts for.
My advice would be to call some more HVAC companies, till you find one, that is willing to fix your unit and not replace it..
May 31, 2010 | Whirlwind FH-778 Air Conditioner
When i press the ac button it blinks three times but does not turn on. 2007 Tahoe LT
If your vehicle is equipped with automatic climate control, this should help.
Recirculation Operation
The HVAC control module controls the air intake through the recirculation actuator. The recirculation switch closes the recirculation door in order to circulate the air within the vehicle. The outside air switch opens the recirculation door in order to route outside air into the vehicle. Regardless of the blower motor switch position, recirculation is available only in the panel and bi-level mode switch positions. Including the OFF position. The mode switch must be placed in either the panel or bi-level position before the blower motor switch is placed in the OFF position. In order to reduce windshield fogging, outside air is circulated when the mode switch is in the defrost or defog positions. If the recirculation switch is pressed into the ON position when the mode switch is in an unavailable mode position, then the recirculation switch LED will flash 3 times. If the HVAC control module detects a fault with the recirc door the HVAC control module will try to drive the actuator for a predetermined amount of time, to outside air, which is the defaulted position for the recirculation actuator
Oct 17, 2009 | 2007 Chevrolet Tahoe
REFRIGERATOR HEATS UP TO 90
gheck and see if your condenser fan working or pull the refrigerator 3/4 off the wall
Feb 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Mitsubishi MSH 18NV no heating or cooling
The fact that nothing is coming on indicates that there is possibly a problem with your incomming power supply or wiring to and from the inside evaporator to the outside condenser. If all in good order, suggest you find someone you know who can operate a multimeter and check if there is voltage going to the control board inside the evaporator unit. If there is then almost certainly the control board would need replacement.
Feb 05, 2009 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
