Question about LG RZ32LZ50 32 in. LCD Television
Black screen , but still got sound ?
Switch the lcd  tv on screen is black as if not on , but sound is coming through and you can change channels so every other function seems to be ok ( TOSHIBA 30")
5 Suggested Answers
  • 3 Answers
SOURCE: lcd tv screen stays black, but with sound
just open up the tv 2 the main bord then look for a littler green button press it and then plug it in and it will work i did it 2 mine
Posted on Mar 23, 2008
  • 187 Answers
SOURCE: After warming up (about 30 min.)my LG LCD TV
replace the mainboard and that will solve your problem
Posted on Jul 08, 2009
  • 21 Answers
SOURCE: lg lcd tv screen goes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 10594 Answers
SOURCE: my LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Posted on Jul 23, 2010
  • 2080 Answers
SOURCE: Have a 42" LG LCD
Sometimes this is an indication of a bad LCD Controller Board (or TCON board). Sometimes it's even just a loose or improper connection with one of the ribbon cables leading into it. When the set heats up the connection expands and makes better contact and functions somewhat better. If you remove the rear access panel you might be able to see the Tcon board. It will probably be under its own metal shield / cover plate. It will have a bunch of wires wrapped in a steel braided shielding cable leading into one side of it through a connector. It will also have 2 or 4 thin flat ribbon cables leading out the other side of it via plastic connectors going to the actual LCD panel. You can google it to see pictures of a Tcon board, it will look similar to the one at this link: You can try flipping up the little plastic retainer clips that hold these flat ribbons in place and gently pulling the ribbons straight out. There will be some gold / copper contacts right on the tips of these ribbons. Sometimes they get oxidized and need to be gently cleaned with a pencil eraser to make them shiny again. Then just slide them straight back in the same connectors and flip down the little plactic retainer clip to hold them in place again. I am assuming of course that the unit is unplugged while you do all this and that the warranty has already expired. If you have any more questions or require additional assistance, please comment back on this page and I will endeavour to help you. Good luck, and if this was at all helpful, please click on the 4 Thumbs Up rating icon above. Thank you very much. Joe.
Posted on Feb 15, 2011
0 characters
1 Points
How do I fix a black screen with sound working and LED light on.
Unplug the set and let it stand for two minutes. Plug it back in and see if it works. If that doesn't work contact Philips support:
Mar 14, 2015 | Philips 42PFL3704D LCD TV
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Flat Panel Televisions
Vizio LCD 47" switching channels takes very long
Has it always done this since you purchased it? Check the response time online for that TV, it may just be that it is a model with poor response time when changing channels. I've seen some value brand TVs that seem to take a full second or more to switch and go blue/black in between while switching.
Very painful to channel surf like that, so if you have a cable box etc hooked up use that for surfing channels instead if you can't handle the wait.
Oct 19, 2012 | Flat Panel Televisions
Soft "Pop", Then Black Screen. Sound is OK.
First check the inverter for any burst capacitors and the display boards.
Aug 28, 2012 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
The tv was working fine the other day. I turned it out today and the screen just stays black. If I press the channel button up or down the channels change and sound comes out. The audio works fine, but the...
Turn it off/on a few times within a few mins each times.U get a flashes of picture about 10 to 20 sec?Than ur LCD inverter board is dead.Tries Websites, to buy a refurbish LCD inverter board for the replacement.It usally a long PC board in shape.
Apr 16, 2010 | Polaroid FLM-3232 Television
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Oct 11, 2009 | Philips 47PFL3603D LCD TV
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
LG RZ32LZ50 32 in. LCD Television Logo
21 people viewed this question
Top LG Flat Panel Televisions Experts
Are you a LG Flat Panel Television Expert? Answer questions, earn points and help others
