50' LG plasma TV has thin lines running verticaly through tv
For no reason my TV now that its out of factory warranty, has two thin lines running through it. They came from noware. Is there anything i can do. Its only out of warranty by about a month.
Re: 50' LG plasma TV has thin lines running verticaly...
HI, this will happen when the power isn't distributed correctly, in return, depriving the main board of its needed current for operations. this will usually produce these lines.
Replacing the power control board will fix this issue.
LG Electronics/Zenith Part Number: 6871QYH039B
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
I had the same problem with a Sony tv a couple of years ago. The cable connection was going through the VCR, then to the tv, so we thought we could try making a direct connnection, and the lines went away! I'm not sure if this is your problem, but if so, this should do the trick.
If not, call a repairman, and they may be able to help.
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
I am assuming it goes all the way across and is black ? It sounds like a scan line in one of the chips inside has gone bad or needs to be resoldered. Most likely needs the board replaced by a tech. Hope this helps Scott
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
