Question about Pioneer SD-P50A5-K 50" Rear Projection Television
High voltage what is the c r t voltage or high voltage for the sd-p40
  • beboy Oct 24, 2007
    i need to know the anode voltage for the crt tube
  • 1,694 Answers
Why? Please give accurate symptoms and I probably can help...T.
Posted on Oct 24, 2007
Grundig p40 540 text
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 21, 2014 | Televison & Video
Pioneer SD-P40
There may be high current in the board as one of the component may be weak or out of order , please check the voltage out of the at the fuse holder , Please change the board ASAP..... or call
For Service & Support Please Contact Us At: 310397382support-icon_small.jpg 1925 E. Dominguez St.
Long Beach, CA 90810
Call (800) 421-1404
Or contact us by e-mail.
Hours of operation:
24 hours a day for most services. Hours for product service, product operation and parts inquires:
Mon. - Fri. 9:00 a.m. - 7:30 p.m. Eastern (all product inquiries).
Sat. - Sun. 11:00 a.m. - 7:30 p.m. Eastern (plasma, DVD recorder, navigation inquiries only).
May 15, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
The set has the 3 strikes and you are out rule built into it.
Set will attempt 3 times to come on and if fails enter shutdown mode.
A short or an issue almost anywhere in power supply or high voltage circuit will cause this.
The only common cause is the set may have developed bad or cracked solder connections where the high voltage transformer solders in.
This happens because of poor soldering and expansion and contraction of the board happens when set gets hot and then cools off.
see attached photo of a high voltage transformer also called a Flyback Transformer.
Apr 28, 2012 | RCA Televison & Video
I have a projector monitor receiver sd-p5046/sd-p4545, , but every 5 or 10 minutes monitor turns black, no picture and sometimes turns off, \r\nand i had to wait, awhile to turn on again
You did not mention if you also lose sound. If you do not, you probably have a problem with the high voltage section. It is failing, shorting, and has not gone completely yet. The flyback specifically is shorting out and needs to be replaced. I have a tip at which explains how to find and replace the flyback transformer and repair the high voltage section as well as where to get the replacement parts.
Thanks for using FixYa and for the great rating.
Feb 19, 2011 | Pioneer Televison & Video
Have you tried to do set the convergence with a pattern on the screen? Some tv's have the pattern built right into the setup. Others do it auto just by pushing a button. Adjusting the pattern on one side of the screen may affect the other side, depending on how far out of whack it is.
Magnets (speakers) near by will play havoc with convergence.
Aug 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P40
Check your hori out put transistor if shorted replace NTE2973, this should be output number.if you need any more help let me know!
Oct 12, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P40
Check to see if Q118 is shorted on video/defl pc
Aug 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
52 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
