Question about Whirlpool LER4634J Electric Dryer
Whirlpool LEQ9030PQ0 electric will not start
Whirlpool leq9030pq0 will not start
    Scholar:
  • 85 Answers
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on Jun 03, 2009
I get a start? when pressing start and oven wont come on my whirlpool electric oven
Terrence, Could be defective oven element, control board, etc. have a good tech. diagnose and estimate repair. Check the attached links trouble shooting,instruction and guides for electric oven, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Whirlpool Oven Won Turn on
Troubleshooting Guide for Whirlpool Electric Range
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Jul 29, 2016 | Whirlpool Ovens
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
Dry won't start when button is pushed yes it has
Bad door switch, possibly. Wire slide connector on the door switch is loose, possibly. These are really simple to fix.
Apr 07, 2010 | Whirlpool WED5900S Electric Dryer
THERE IS NO HEAT IN MY WHIRLPOOL DRYER MODEL LEQ9030PQ0
Check the dryer twin breakers in the house electrical panel--push off, then on. If breakers hold, then try the dryer again. If it heats, you are good to go. If it trips the breakers again, there is a direct short in the dryer itself, usually in the heating element(s). The drum must be removed to access the element(s).
Sep 07, 2009 | Dryers
Whirepool electic dryer leq9030pq0 will not heat up I replaced thermal switch and cut off. only switch not replaced has 2 purple wires going to it. How to tell if coil is bad
The heating element should read between 9 to 13 ohms if good. You need to disconnect the leads to ensure you don't read any parallel resistance paths. In addtion, you may want to pull the element from the heater box and physically inspect the coil for breaks.
Jun 25, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Electric Dryer wont turn on
Try this;
In your browser bar type in youtube.com
In the search box type in repairing whirlpool dryers
Then click on the apprpiate video.
This should help you.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryer Won't heat
tested the thermal fuse inside back of dryer??? if so id check the heater and 2 other thermstats right there on back wall behind panel
Mar 15, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
288 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
