Power light on the adapter but no power going into the laptop.
Every so often when i plug in the adapter to charge my laptop it does not charge, no power enters laptop and will not turn on. Its strange because a few hours later it works again. I think its a faulty main board for the power. Rang acer they believed it was a faulty battery but it seems that the batery is fine. Sending it off for repair tomorrow hopefully it will solve the problem...
    Problem Solver:
  • 17 Answers
BECAREFUL because if its under warranty your okay, if not be prepared to shell out big bucks . the opening on te computer , where the plug connects is the problem, alittle solder and its fixed one day job did that type of repairs many times freddiemccly@yahoo.com
Posted on Jun 04, 2009
.new acerpsweo laptop r cord butit does not charge laptop and go ina second how can a fix it how can i downlod my files?
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 02, 2013 | Gateway Computers & Internet
The adapter stopped charging my laptop due to a faulty wire, I bought a new adapter and now as soon as I plug in it starts for a second and turns back off. The charging light blink and it doesn't
Jan 28, 2013 | HP Compaq Presario C509NR Notebook
I have a msi tab. When I charge it was'nt charge
Dec 08, 2012 | Computers & Internet
Aspire on charging point problem
Nov 29, 2012 | Computers & Internet
I have lenovo 44463fg laptop why it is not charge do you tell me the charging ic name thanks
Nov 07, 2012 | Lenovo Computers & Internet
My gateway nv79c54u laptop ac plug doesnt charge just blinks orange
Sep 12, 2012 | Acer Gateway NV79C54u 17.3-Inch Laptop...
Laptop battery plugged in but not charging
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 03, 2012 | Computers & Internet
When i plug laptop in charging light come on then goes off also in bios mode the left batery says charging but show no sign of charging ...so is it the battery or what
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jul 11, 2010 | Dell Latitude CPX650 Notebook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
Inspiron 1420 dell says plugged in not charging
Feb 22, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Computers & Internet Logo
David Payne
David Payne
