Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
How to change oil and where i put the oil in to the lawn mower mtd 3.5hp / 20
  • 376 Answers
Warm up the engine so the oil will flow out. Push the handle to the ground and either have someone stand on it or wedge it underneath something to hold it down. Disconnect spark plug!! Remove blade. Place a drain pan underneath mower (one that's shallow enough to lower the mower down on) and using a 3/8 extension on a ratchet, stick the square end of the extension in the drain plug in the bottom of the engine and unscrew. Lower mower back down for a couple of minutes then reverse proceedure. I think it holds about 20 oz. of oil. Put in 18 oz. and check it. Be sure not to overfill.
Posted on Jun 03, 2009
Lawn mower stopping by itself
CHECK THE FUEL FOR CONTAMINATES OR OLD GAS
EMPTY COMPLETELY OUT AND PUT IN NEW GAS!
ALSO CHANGE SPARK PLUG!
IF YOUR LOW ON OIL, IT MIGHT AUTOMATICALLY SHUT OFF ALSO!!
Jun 15, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How much oil do I put in my Mtd Gold self propelled mower
most push mowers are about a half a quart
May 11, 2012 | Mtd Garden
How much oil goes in a 22'' inch MTD yard machine push mower
Most normal push mowers require 20 ounces of engine oil. I recommend that you use only SAE 30 oil and try to use synthetic.
May 01, 2011 | Mtd 22" Yard Machine Push Mower
I have a mtd 6 hp push mower,what type of oil should i use for it?
Lawn mowers with engines smaller than 10 hp use a "splash" oil system for lubrication. Therefore you should use a standard SAE 30W non detergent oil. Per most user's manuals oil changes are every 25 hours of use. Every 4th oil change you can use a detergent 30W oil. Doing this will clean the inside of the crankcase and all components to the point the look brand new. It will not hurt the motor or the seals in the motor. However after this cleaning 25 hour period with the detergent oil, you should go back to SAE 30W oil again.
Kelly
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
Changing oil in my mtd lawn tractor!! Was oil should I use? Where is the filter? How do I change it?
Most Mower engines have an oil drain plug located at the base of the oil fill tube or dip stick tube, Most mower engines use a standard 30wt engine oil, however, to stay within the parameters of your warranty, use the manufacturers reccommended oil, this info can be located in your owners manuel.
Apr 14, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Oil change in yard man lawn mower. i am unable to find a drain plug
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
Dec 05, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machine push mower needs oil changed. How do I know how much oil to put in it. No Dip Stick
when you unscrew the oil cap is should have an oil level mark on the side of it.
Jul 27, 2009 | Mtd 22" Yard Machine Push Mower
Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Jun 12, 2009 | Mtd 22" Yard Machine Push Mower
Oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
May 27, 2009 | Mtd LAWN MOWER PART # 782-0082A-0638 DECK...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
303 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
