Question about GE (PSS26MSRSS) Side by Side Refrigerator
Compressor not working warm fan inside frezer run
GE side by side Compressor not working warm fan inside frezer run no cold air
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Posted on Jun 05, 2009
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer works but the refigerator section does not. When you turn the temp switch for the refrigerator it will turn off the freezer also.
dont tuch the thermostat put it in normal setting!
now, check if your fan in the frezer working, if it is working che3ck the thermostat unit and heater in the frezer unit also need to see if the frosting is eaven all over in the frezer side..
contact me at www.911servicetoday.com
Dec 30, 2009 | Refrigerators
Yes I have a Maytag side by side frig.....it needed the bottom of frig and compressor area cleaned badly....so I used a small vacuum and some air from a small air tank to clean it and blow it out dirt and...
is your compressor run? is the fan working? cleaning can damage only if it break parts...
but if all is correct and you didnt damage the gas in the pipes... the problem is in your frezer unit and you need to check the back wall inside your frezer to see if the fan working and the defrost is eave...
Dec 30, 2009 | Maytag MSD2656G Side by Side Refrigerator
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Fridge does not get very cold,compressor comes on, frezer is cold
check to fan inside unit air not transferring from freezer to fridge fan uses cold air from freezer to cool fridge check that fan is working usually can feel but may have to push button on door and hold if no fan remove cover and check for ice on blockage if none have fan serviced or replaced -if fan is working properly, same area is a damper that my be blocked or frozen good luck and thank u for using fixya
Oct 14, 2009 | GE Refrigerators
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge warm at top cold at bottom
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
May 28, 2009 | GE Refrigerators
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Dec 31, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
274 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
