Question about Brother ML-500 Typewriter
Not printing a letter when the key is pushed.
How do I correct the problem of not printing a letter when the key is pushed. It is intermittent and only on two keys K and X. I have never taken the machine apart nor do I really wish to. I assume something is allowing contact between the key and electronic part of the machine . since it is intermittent I assume it can be fixed.Guidance would be helpful.
    Master:
  • 409 Answers
If you are lucky the Typewriter will have switches under the keys. You will need to take it to a repair centre to have the 2 switches replaced.
The other alternative is to replace the whole keyboard.
It may be worth getting a can of spray duster (air in a can) and seeing if you can blow out any crud that may be there.
Posted on Jun 03, 2009
Letters are not printing correctly
try resetting the language with the lang key
Jan 29, 2014 | Nakajima AE-710 Typewriter
Why is it that my typewriter isn't typing the correct letters that I'm pushing? I've tried turning it on and off as well as the reset but it continues to type whatever it wants to.
Hi The print wheel in you machine has to be the same language as the machines key board
if its the same wheel you have all ways used the we have two things to look at
1 the print wheel must not have any bent legs on it as they will catch and the machine will print rubbish. also remove the correction tap as this can get stuck in the wheel.
2 it its just the occasional character that printing wrong the you probably have the machine set to key board 2 this is explained in you user book you can get one from Brothers web site
if this helps please take the time to rate me thanks ian
Mar 08, 2011 | Brother GX-6750 Typewriter
Our keys are wrong. We hit an A and it comes up a K. All the keys type a different letter.
Make sure that you loaded a correct printhead for the typewriter. If it is correct, is the print head loaded correctly?
Feb 24, 2011 | Brother GX-6750 Typewriter
We have a IBM Wheelwriter 5. Need to use
Correction is pretty simple type a letter, press the correction key and it should lift the wrong letter off.
DickyO
Sep 30, 2009 | IBM Wheelwriter 30 Typewriter
I am trying to type a letter but when I strike the letter g it types a $. None of the keys seem to be lined up with the correct letter on the wheel. How do you correct this problem?
there is a slide switch on the L.H. side of the key board that reads 10,12,15, PS
the switch needs to match the print wheel stile you have in your typewriter. most typ's have 10 or 12.
PS stands for proportional spacing a takes a spicule print wheel
Jan 14, 2009 | Nakajima AE-710 Typewriter
Letters & numbers not printing correctly
The most common reason for this is something interfering with the printwheel. Turn off machine. Take out the ribbon, then pull back on the black lever to the right of the printhammer. This will tilt the printwheel towards you. Look to see if there is anything caught in the printwheel. Also check to see if the corr tape is installed properly. Corr. tape and ribbon should both be between the two metal fingers and the metal cardholder. Push the black lever forward and look to make sure the two metal fingers are not bent into the printwheel. If they are, simply push them forward and bend them so they don't. Re-install the ribbon, making sure it goes on the other side of the fingers. Turn machine back on and test machine. If it still doesn't work, you will need a trained technition to determine the problem.
Sep 18, 2008 | Brother GX-6750 Typewriter
Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Aug 21, 2008 | Olympia Mastertype 3 Typewriter
NEC Dterm 80 display
It took me forever to find out, but heres what you do.
with the phone hung up:
1) "Feature" then press "1"
2) then press "#", "*", "#"
3) lift the phone, then hang up
4) press "Speaker"
5) dial "700"
6) press "hold"
7) enter the name (I'm still trying to find out how to leave a space, or use aother character that the same number key has... ugh"
8) press "hold" then "Speaker"
then make sure it saves it in the directory
Jul 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Only half my letter's work!
you are correct, the number lock is on, use the blue "FN" key and in blue under the "ins" key you should see "Num LK" push the two together and presto, normal keyboard
Feb 28, 2008 | Compaq Armada E500 Notebook
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Brother ML-500 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
