Question about HP LaserJet 1100 Printer
Connect to usb on laptop
Am trying to hook up old hp1100 printer to laptop. Printer cable ends with 25 pin male. I need to get that in to usb connection on laptop.  Please advise.
    Problem Solver:
  • 8 Answers
Wal-Mart Supercenters also have this adapter.
Posted on Dec 07, 2007
The Easy affordable solution:
www.sewelldirect.com or (801)356-3823
* USB to Parallel Adapter, part # SW-1302 ($14.95) + * Centronics to Mini Centronics, Part # SW-2104 ($12.95).
I ordered before 2pm EST and received two days later.
Plug usb into computer, wait, then plug in printer. Voila! Instantly worked!!
PS: Found this site after www.monoprice.com Product ID: 2277 (parallel to USB) and ID 257 (male to mini) - $15
Posted on Nov 06, 2007
Kids gave me a printer/scanner Epson model number c171a. Need the cable to it. AN oldie but looks like a pretty nice printer. Can you help??
The cable you need depends on the unit. I am not aware of a C171a model from Epson. I have seen it listed as a version of the RX500. In that case you need a USB cable with A/B male ends.
Otherwise, most printers (from about 1997 on) will use a USB cable. This has two male ends - a square end goes into the printer and a rectangular end that goes to the computer (called A/B). For older printers (there may be multiple ports or just one), you may see a parallel port (the cable has a wide rectangular plug on both sides with 36 pins) or serial port (the cable may have DB9 (9 pin), DB25 (25 pin) or both). Often it is called a RS-232 port. For a parallel port connection, you would need one that is designed for scanners and bi-directional communication (USB to parallel adapters are available to connect this to a new computer but you still need the bi-directional version). Similarly, USB to serial adapters are available.
Generally you can tell what cable you need by looking at the back of the unit where the ports are. (Although some all-in ones have the USB cables in other places - routed through the side of the unit but the plug is near where the ink cartridges go.) Then the size and pin counts for parallel or serial tell you what cable to get. There is usually a symbol indicating the cable type as well near each port. USB cables are usually indicated by a tree like symbol with curved branches.
I hope this helps.
Jul 25, 2010 | Epson Office Equipment & Supplies
What printer do I use to connect an Officejet d135
A printer does not connect to a hard drive.
Is the connector on the PC a Male (Parallel) or Female "D" (Serial) shaped connector?
Does the PC have a flat USB connector you can use?
If it does, then you should be able to purchase a cable that has an "End Point Connector" The "U" shaped block and the other end is the flat conector that is oon just about everthing.
Don
Feb 06, 2010 | HP OfficeJet D135 All-In-One InkJet...
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
I have an old HP deskjet 3820 printer and a new HP pavilion desk top which has only USB I/O ports, no parallel ports. Therefore I need an adapter cable to connect my printer to my new PC. Does the adapter...
You can almost buy a new printer for the cost of the adapter you are talking about buying. They have all kinds of adapters: the kind that connects to the flat end of a USB or the square end. Parallel, male or female. Go to a computer store like best buy, they should be able to hook you up.
Hope this helps.
Dec 10, 2009 | Cars & Trucks
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Large data transfer laptops, cable, or USB adapters DELL Lat-C
the system must surely have a ethernet port... why dont u try a peer to peer connection.... they can achieve very good speeds...
Nov 23, 2008 | HP Pavilion dv9000z Notebook
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
Needing to hook up my scanner
You are going to need a 25 way cable a "Printer" type cable, A Male to Male, BUT with ALL 25 pins wired thru pin To Pin. This plugs straight into the "Printer" port. These machines often have a "Pass Through" port on them so ya can also connect to a Printer, however if ya printer is USB then it's NOT used. I found drivers below. http://www.opendrivers.com/ driver/211491/ umax-scanner-astra-1220p- vistascan-3.55-parallelport-free-download.html
Sep 01, 2007 | Umax Astra 1220P Flatbed Scanner
HP LaserJet 1100 Printer Logo
176 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
