Question about Oreck Super-Deluxe BB870AD Bagged Canister Vacuum
Oreck canister bb280d
The plug on the vaccum is all freyed and we need to replace it with a  new plug. How do I get the old one out and how do I put the new one in?
  • 3 Answers
If the plug is "frayed" that's one thing. If it's "freyed" or fried or fired, you got me!
Posted on Oct 24, 2009
    Problem Solver:
  • 9 Answers
Fairly easy if you can work a power drill
Posted on Dec 06, 2007
How do i open xlcannister to put new bag in--
http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1426568065661/images/userguides/Canister-LittleHero-BB2000-userguide.pdf
Sep 28, 2014 | Oreck BB2000 XL Little Hero Canister...
How to put shoulder ******** oreck bb280d
The manual is available as a PDF here: http://www.oreck.com/Owners-Guides . Scroll down to the Canisters section and then select the link for the Compact Canister vacuum.
Apr 03, 2013 | Oreck Vacuums
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
Replacement belt Oreck UPR014T XL
Ok its sounds like you need a new brush roller and change your belt
Aug 13, 2012 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Hi, I purchased a used Oreck BB870-AD canister vacuum cleaner, but it didn't come with the manual or any bags. Can you tell me where I can find the manual & what type of bags do I need?
The replacement bag that you should use is: Oreck Replacement Treated Filter Bags (12 pk. with
1 Micro Filter) No. PKBB12DW which cost $14.99 for each package from Oreck. On the Oreck site, these are the Hand-Vac Bags. See: http://www.oreck.com/Hand-Vac-Bags to order them online.
I hope this helps.
Mar 21, 2011 | Oreck Vacuums
I bought a replacement brushroll because the one in the vaccum cleaner is worn out.How do I go about putting the brush in the vaccum cleaner. Do I pull it out or do I have to unscrew the entire bottom...
Greetings from GoVacuum,
Make sure the vacuum is NOT plugged in. In order to replace the roller brush, you'll need to unscrew the 6 screws on the bottom plate of the vacuum cleaner. Oreck uses a Phillips Head screw, so you'll need to get a Phillips head screw driver to replace the brush.
After removing the screws from the bottom plate, simply pull up on the plate by putting your fingers into the open area where the existing brush is located. After the bottom plate has been removed you will have access to the roller brush and belt.
You can now just grab the roller brush and pull straight up on it. It's beneficial to change the belt of the vacuum when you're replacing the roller brush anyways. There is a spare belt on the actual bottom plate of all Oreck XL vacuums.
You'll notice that the new roller brush has two black square plastic caps on both sides of the roller brush. You can look on the outside of this black cap, and you'll see the words OLD and NEW. Rotate the NEW side so it's facing upwards, and the OLD side is the side that's down inside the vacuum cleaner, make sure that both sides have the NEW side facing upwards. You'll need to wrap the belt around the silver pin in the back of the vacuum on one side, and through the roller brush's metal pulley on the other side. The just stretch the belt with the brush inside of it, and place the black plastic parts back into the vacuum cleaner.
Congratulations, you've now just replaced the roller brush in your Oreck!
Please feel free to email me if you have any questions on how to complete this repair, or just request a clarification through this Fixya page. My email address is chris.jones@govacuum.com.
If this repair solution was helpful, please be sure to rate this repair as helpful by clicking the 4 Thumbs Up icons in the top right hand corner of this repair solution.
Be sure to check out http://www.govacuum.com for all Oreck vacuum cleaner parts and supplies!
Chris Jones
GoVacuum.com
Mar 16, 2010 | Oreck XL2000 Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
A friend gave me her Oreck 1400 canister vac. It's like new, but has no "filter bag carrier." Where can I get one?
Sadly, your best and probably only bet for this is either an Oreck dealer or by calling the 1-800 line for Oreck customer service.
Aug 02, 2009 | Oreck DutchTech DTX1400BD with Powerhead...
ORECK VACCUM
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=747767
Generic problem for all Vacuums
ORECK VACCUM
Posted by FISHERMAN928 on Jul 06, 2008
Older Oreck XL, new belt, new bag, checked for clogs, does not pick up
as it used to, and, much harder to push, seems to grab or drag, why????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that may work. Depending on if you have the old style brushroll you can upgrade to a new style Oreck brushroll that has twice the brushes and will a work a lot smoother. Also, clean the bottom plate – get rid of any dust and dirt build up and then spray the bottom with silicone and let it dry after you have totally cleaned it. Always use Oreck genuine belts and to change the belt every 4 to 6 months for the best cleaning and store the extra Oreck belts in a Ziploc bag in the refrigerator, other wise if you have a new belt, gag, you have checked for clogs there is no reason why it should be hard to push, if the silicone does not work replace the bottom plate.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Oreck Super-Deluxe BB870AD Bagged Canister Vacuum Logo
558 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
