Question about Sony KDL-32M3000 32 in. LCD Television
White lines slow movement
Same tv, same problem. Did anyone find out what the problem is?
    Novelist:
  • 65 Answers
Supremewingz, overheating may cause the problem, but its actually darkening because of heat. It's like Mando Mojica said.
This is actually a common problem with this model, and its surprising that it really does look like a video board (BM board) problem. It is actually a problem with the panel itself.
Here is the fix:
http://www.youtube.com/watch?v=9UrTVEC5LkA&feature=related
This guy was kind enough to post it. I recently did the repair on a KDL-32M3000 and it worked like a charm. Took surprisingly long, but worked like a charm. I didn't have a 10 Ohm resistor laying around, so I used 2 x 4.7 Ohm resistors in series.
Posted on Dec 09, 2011
Bad panel . overheating turns panel dark,reddish ,blurry
Posted on Nov 19, 2009
  • 643 Answers
Panel is starting to seperate. usually covered under manufactureer warranty. wait m3000 is older model. then its usually not recomened to replace panel not very economical.
Posted on Jun 03, 2009
Wavy line on a DLP SAMSUNG 65 INCH PROJECTION TV
Bulb does not do anything but project white light. Wavy lines are a digital board problem. You should have a tech look at it.
May 20, 2015 | Samsung Televison & Video
The tv is slow to turn 20 -30 minutes
The tv Tuner board is dead.Need the Tuner replacement,that the board,where the air incomming brocasting signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Aug 03, 2010 | Toshiba 26LV47 26 in. LCD TV/DVD Combo
Moves very slow, 5 years old
With these pool cleaners, slow movement could be caused by several things. Try these troubleshooting tips. Check to make sure that all suction lines are closed except the line that you are using. Make sure that there is no debris caught in your filter or pump basket that could impede movement. Check your flappers for debris. Debris could impede water flow and movement.
Jun 22, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
Plasma TV moving black and white lines
This is a result of poor conversion of a SD signal on a HD channel.  Go into your settings and adjust the h/v settings to move the line off the screen.  You can do this with a combination of v-position or vsize.
Jan 26, 2009 | Vizio GV42L 42 in. LCD Television
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Lines keep scrolling down.
I had this same problem and unplugged the TV from the a power strip and plugged it directly into the wall... problem solved.
I read elsewhere that this is called a "ground loop."
Aug 21, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Sony KDL-32M3000 32 in. LCD Television Logo
535 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
