posted by mfcboy on Oct 24, 2007
recently i found there are some problem with my all-in-on system. receiving incoming fax in the memory, displaying "memory received" but never print out.
I wonder if there is a way to retrieve fax from memory and print out manually?
Comment by mfcboy, posted on Oct 25, 2007
i refilled toner and now machine still flashing "toner empty" but printing is ok. maybe it does matter?
Comment by mfcboy, posted on Oct 27, 2007
thanks,omnipresent,I tried to find where the fuse is,but came out there is no fuse in my particular toner. just forget about it. receiving fax is not major work for me.
Comment by mfcboy, posted on Oct 30, 2007
Best Solution
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I am having the same problem, the manual says it should print out itself. However this is not the case... I installed the disc that came with the machine, however no luck. It appears we may have to take it to the repair facility.
Rating Locked! (?) mfcboy has rated this solution as FixYa!
Solution #2
I had the same problem and the solutions is simple. omnipresent is right that WHILE USING REFILLED TONERS , THE MACHINE DOES NOT SENSE THAT TONER HAS BEEN REPLACED but you don't need to speend money for new cartridge head. All you have to do is to set the maschine to ignore the Toner Empty Alert. You can easily find this option in your SCX-4521F menu. Good luck to all of you.
For more questions you can whrite me at: iliya.georgiev@gmail.com
Solution #4
posted on Oct 26, 2007
WHILE USING REFILLED TONERS , THE MACHINE DOES NOT SENSE THAT TONER HAS BEEN REPLACED , THEREFOR IT WILL NOT PRINT YR FAXES.
YOU NEED EITHER REPLACE WITH A NEW TONER CARTRIDGE OR USE A CSENSING FUSE CHIP ON THE TONER TO MAKE IT SENSE THE REFILLED CARTRIDGE
haPPY FAXING
OMNIPRESENT
haPPY FAXING
OMNIPRESENT
Rating Locked! (?) mfcboy has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Samsung SCX-4521F All-In-One Laser
Email this problem
Email this problem
Can you Help with these Printers problems?
Samsung SCX-4521F All-In-One Laser Printer
Fax can't be received by one...
As per subject. This seems to... Answer This...
Fax Machine Samsung Model...
My machine has been receiving... Answer This...
problem with printing
i keep on continually getting... Answer This...
Repair Service
Find Printer Repairman Near You:
