Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
I have a Sony KDF-50WE655. It is 5.5yrs old. There are blue pixels in the middle and blue blurs in the corners and its getting worse. It was registered and I have received no recall notice. I had the extra 3yr warranty which has expired. Realistically, what can I do?
  • kgb Jun 03, 2009
    Hatman-thanks for you quick help. It is appreciated very much and gives me a starting point to fix the problem. Again-thanks!!!
  • 126 Answers
Sony has extended the warranty on many of those units for the light engine. And that is what is wrong with your set. You need to look around for an authorized Sony service center in your area and call them with the model and serial number. They will tell if yours is covered. Better hope so, cuz that is a very expensive repair out of warranty.
Posted on Jun 03, 2009
Blue-ish hues in left corner and middle of tv. getting worse sony kdf-55wf655
The Optical Block assembly must be replaced to fix this. This assembly runs around 800.00.
It has been a common problem and Sony had a factory recall on the Optical blocks but I believe that has expired over a year ago. To double check on that you can call them at 1800-222-sony.
I hope this helps,
skyassoc
Dec 08, 2010 | Televison & Video
THE CORNER OF MY SONY 42" VVEGA IS BLUE AND HAS BLUE SPOTS
your light engine is bad call Sony and see if it is one of the models on extended warranty
Aug 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue patch on screen KDF-42WE655
This is problem of Optic Block (light-engine) that will be replaced and it is costly fix.
Click HERE to get price info and part image.
May 07, 2009 | Sony KDF-42WE655 Television
3LCD Projection TV 2.5 years old displaying blue hue/blobs
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
Dan
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue streak at bottem of screen
You have the classic "blue blobs," In most of Sony's rear projection LCD's, the Optical block is bad. Manufacturer's defect. The blue panel inside of the optical block starts de-laminating (due to heat from the lamp). This is a very common problem. I have changed about 70-80 optical blocks myself over the course of about 4 years.
There is no other fix but to replace the optical block. Unfortunately, it will get worse, and will probably develop "stars," or stuck pixels, as well. You can call Sony and try to get some assistance, but the extended warranty on these sets has recently expired.
Hope this helps you in some way...
Jan 04, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue hue on bottom of screen We have the same problem. A blue hue extending the bottom of the screen and now is working its way up the middle .
call SONY at 800 222 SONY and explain it to them and be prepared to have your TV fixed for free !!! the projection block is faulty do to outsourcing on that part for a limited number of tv's an mine was 1 of them , SOny took care of everything !!! good luck
Feb 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to Sony.com for customer service. Good Luck
Nov 21, 2007 | Sony KDF-E55A20 55 in. LCD Television
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
384 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
