Everytime we print on our Sharp AL-1655CS printer it makes a loud grinding noise. We called Sharp and they said that we were using the wrong drum. They said because it was not their brand it caused a problem. We changed back to their brand and it got better for about a minute. Now it is extremely loud. It fills the entire office with noise when someone prints. I checked the drum and it is leaking black dust.
The black dust is toner. Be carful as it is carcenagenic (dont get it on your skin) you will need to dispose of the leaking toner cartridge and get a new one. also you will need to clean the printer very carfully to get rid of the spilt toner. A combination of spray duster and a toner hoover are the best way. do not use a normal hoover as you will kill it.
It is always possible that you have done serious damage to the printer using a non standard toner cartridge. I would recomend getting a qualified person to give the printer a good service.
That reply doesn't even answer the question. The question was what is causing the problem not how to clean up toner. Also, I highly doubt that aftermarket toner drum would damage machine. They are made to manufacture spec without the huge markup.
Was this helpful?
Yes
No
Popular Solutions for Sharp AL-1655CS Laser Printer
I am attempting to install the drivers for the Sharp AL-1655CS printer that is connected via the...
(More)
I am attempting to install the drivers for the Sharp AL-1655CS printer that is connected via the network. When I get to the step where I am supposed to select the printer I want to install from the list, it is not there. I tried typing in the IP address/printer name and that seemed to work. I completed the installation but I cannot print. The printer does not acknowledge that a document is trying to print.
Printer is making a loud grinding noise and will not print anything. Readout flashes system error...
(More)
Printer is making a loud grinding noise and will not print anything. Readout flashes system error L1-00. WE have only had this printer about a year and everthing is still the original. help!! Sharp AL-1655CS Laser Printer
