Question about Gestetner DSm618 All-In-One Printer
Gestetner 3225 When the copier starts to print it gets an error SC320. Do you know what the discription of this error is?
  • Ken Russell Nov 16, 2007
    Exact same problem SC320 Error on startup
  • 37 Answers
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Posted on Nov 22, 2007
I have a Gestetner 1802 and today it says functional problem SC320. Can you explain what that is?
Most likely what is called the polygon motor in the laser is bad. It is the motor in the laser unit that has mirrors mounted to it . It is the scaning part of the laser.
Oct 06, 2010 | Gestetner Office Equipment & Supplies
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
Sc320 functional problem
YOUR PROBLEM IS IN THE LASER ASSY. FIRST GUESS IS THE POLYGON MIRROR MOTOR.IS SLOWING DOWN AND NEEDS REPLACING.USUALLYYOU CAN HEAR A WHINING NOISE AS
THE MOTOR REVS UP APPROX.30000RPMS. SC320 DOES NOT MEAN THE SAME THING FOR EACH MODEL BUT IT DOES MEAN A PROBLEM IN THE LASER UNIT
Apr 29, 2010 | Gestetner Office Equipment & Supplies
Error SC320
your polygon mirror motor has stopped turning. alot of reasons why. 1 bad mirrior motor. 2 need to oil motor. you have to use thin weight oil 5w. 3 power supply. 4 laser. 5 sync pcb. 6 motor fialed becasue of cooling fan
Jan 02, 2010 | Gestetner 2712 Digital Imaging System...
We have a gestetner DSm622sp we are getting an error code SC320.
Hello sir; the error code you have display, that's means laser motor don't work, replace it!
May 18, 2009 | Gestetner DSm515pfd Digital Copier -...
Error SC320
The laser motor is cooked
Apr 12, 2009 | Office Equipment & Supplies
Gestetner 3225
SC401: Transfer roller leak error 1
SC402: Transfer roller leak error 2
-Definition- [B]
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Transfer/separation unit set incorrectly
Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Ricoh 1022 - Error SC320
USE A BIG PHILIP SCREW AND REMOVE THE 2 PCS SCREW IN LEFT SIDE AND REMOVE THE COVER WHERE THE PAPER IS EXIT. YOU SEE A BLACK BOX INSIDE, AND USE A SMALL PHILIP SCREW TO REMOVE THE 4 PCS SCREW LOCATED IN HOLE. THEN LIFT UP THE BLACK BOX AND OPEN IT. BE CAREFULL
Mar 02, 2008 | Gestetner DSc332 Copier
Gestetner DSm618 All-In-One Printer Logo
234 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
