Question about D-Link DSL 200 (DSL-200) Modem
My d linkflashing and disconnected after minute or
My d link flashing and disconnected after minute or so
  • 113 Answers
Turn off the power and turn it on. how long its happening.go to command prompt . type the cmd ipconfig u ll get the default gateway open the internet explorer and type the default gateway u ll get the d link page and check if the router is connected to the ur isp, if not click on connect, if its asking for user name contact ur isp to get connected to ur isp. if its happening frequently need to b reported to the isp as it might be isp issue
Posted on Jun 04, 2009
One of my TP-LINK 500Mbps has stop working .What can I do to fix it
I have to assume you are referring to TP-Link power line adapters. In any event, pick the one that is not working. Press and hold the Pair button for a second or so, the Power LED will start flashing. Wait 2 minutes, then press and hold the Pair button of your main (other) TP-Link for 1 second, the Power LED will start flashing. In about 2 minutes all should be good.
If not you may have to reload the flash software or use the disks to reset.
Cheers
Jul 13, 2017 | TP-LINK Computers & Internet
2009 chevy traverse wont start after hooking amp up car was fine
OK. you had the battery disconnected. Here is what you do. Turn on the key. The security light will begin to flash. Wait (about 10 minutes) with the key in the ON position. The security light will stop flashing. TURN OFF the key. Then, turn on the key and start the car. Security system is supposed to prevent theft for a 10 minute delay. This usually discourages any thief. This will work, You just need to be patient with the 10 minutes. It seems like an hour when you wait ten minutes for that security light to stop flashing.
Mar 19, 2017 | 2009 Chevrolet Traverse
Power went off and red on-off flashes
After you disconnect from AC, wait for a minute, connect again, power on, and count the number of times it flashes....then google the "x" flash on a "XXXWWW" brand TV. Number of flashes is a code so you know what hardware failure might be. Good Luck!
Oct 15, 2015 | Televison & Video
My air bag light is coming on and off
Airbag warning lamp actually talking to you by number of flashes.
Let's say, two flashes, short pause, then four flashes. repeat same for few times.
This means, code 2-4.(24)
number of flashes before pause shows first digit then flashes after pause shows second digit.
Find what your truck telling you.
Then google "Dodge SRS code" with your year and model.
(every manufactures use different codes)
most common is seat belt explosive connector.
Seat belt retractor has small explosive inside.
in case airbag deployed, this small explosive explodes and lock seat belt besides physical ratchet type locking system.
when you move your passenger/driver seat a lot, sometimes it makes bad connection of this wire then trigger SRS warning.
But not sure if this (seat belt connector) is your case.
Check exact code (count number of flashes) then find out what was cause then fix it.
after you (or someone) fix it, disconnect battery for few minutes then re-connect should clear SRS warning.
If it still come up after you disconnect and re-connect battery, problem was not fixed.
If you check connection by yourself, be sure DISCONNECT BATTERY and WAIT MORE THAN 5 MINUTES before touch any yellow connector (Airbag related connector).
Why disconnect battery? (just negative side is enough) because maybe you will touch wrong wire and accidentally deploy airbag. It will cost you $1000 to replace airbag once it deployed.
Why wait for more than 5 minutes after battery disconnected ?
Battery maybe disconnected when traffic accident occur but airbag should be deployed.
So, airbag has small amount of backup battery for just enough to work for few minutes after vehicle's electronic system was disconnected by traffic accident.
Hope it explain basic to you.
Jul 15, 2014 | Halonet 98-03 DODGE DURANGO / 00-04 DODGE...
TX-32LZD81 fault red led flashes 13 times, repeating regularly after being taken out of standby. The led goes green initially for several minutes before it starts flashing
13 flashes denotes a fault to its main board. If you wish to get more details about these blinking codes, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 18, 2013 | Panasonic Televison & Video
Hoover ultima code F-02 flashing
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jul 17, 2009 | Washing Machines
91 chevy 1500 ac light flashing
try disconnecting the negative battery cable for ten minutes to reset the computer.
good luck
Jun 24, 2009 | 1991 Chevrolet K1500
How do i clear the "service engine soon"
Disconnect the battery for a minuit and turn on the light's to power down any electrical power. Reconnect the battery and that should clear the "servie engine light soon",but if there are any DTC codes, the "Service engine light" will come back on.
On board diagnostic (OBD) was designed on vehicles equipped with electronic fuel injection so you can generally retrieve the codes yourself. No need buying a scanner or running to any parts stores to check the Engine Light. This system is called obd1 and applies to most vehicles made before 1995 for domestics and 1993 on imports.
For GM domestic vehicles made before 1995, the diagnostic connector is located under the dash panel by the driver side. To get the check engine codes to flash in your dash panel, use a jumper wire or a paper clip and connect terminals A and B of the diagnostic connector. Turn your ignition key on with engine off and the codes should start to blink. All codes should start with code 12 which is one long flash followed by 2 short flashes. This code 12 means the diagnostic system is normal and will repeat itself continuously if there are no trouble codes. Otherwise, code 12 will flash 3 times before flashing the fault codes.
the codes can be erased or cleared by disconnecting the battery negative terminal for 1 minute and reconnect. Just make sure to check your service manual in case you have electronic equipment such as radio or clock that needs reprogramming in which battery disconnection is not recommended. Finally after performing repairs on the culprit code, always go for a road test to confirm if the problem is fixed.
Good luck and hope this help, here is a link to the DTC codes. http://www.gmtuners.com/OBD1_DTC.htm
May 08, 2009 | 1989 GMC Sierra
D-Link DSL 200 (DSL-200) Modem Logo
168 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
