Question about Buffalo Technology (USA), INC. - 500GB DRIVESTATION EXTERNAL USB 500 GB Hard Drive
Buffalo hdd itb with bad sectors
How do i fix
    Master:
  • 409 Answers
Bad sectors ona drive is normal. The modern High capacity drives actually have more capacity than they tell you so that when bad sectors appear they swwap them out for good ones. So I would not worry about it, unless there are lots. How did you discover the bad sectors?
Go to http://www.grc.com and download spinrite. That will have a good go at fixing the bad sectors.
Posted on Jun 03, 2009
How to fix damaged hdd's sectors ????????
By the amount of realocated sector count it is conclusive yr hardrive is failing. Back up your data to another drive ASAP and replace the faulty drive.
If you need to get back all your data from the faulty drive and it doesn't work well you shoulod consider HDD regenerator. It is the ONLY software around that works in these instances and it has saved me Several times.
But do no think it will cure the drive !
Like i said: Back up all data & replace the drive ASAP...
Nov 18, 2014 | Computers & Internet
Data error(cyclic redundancy check)
harddrive is dead or bad sectors, try using vivard on ultimate boot cd to fix it
Oct 27, 2013 | Buffalo Technology Buffalo MiniStation...
View Link. But under answers, someone mentioned "Bad Sector", after reading the description, any fixits I can do?
BAD SECTORS
When a hard drive has bad read/write sectors it means the magnetic oxide layer on the disc platters are failing. Before you made an image of the hard drive you should have ran Error Check on the C Drive. This checks and locates the bad sectors and moves the data to an undamaged part of the disc platters and then locks out that bad sector so data cannot be written on the bad sector.
I recommend you do a fresh Windows install on your new hard drive to fix this problem and install the laptop's device drivers plus your programs and data before the hard disk fails completely.
Mar 25, 2013 | Computers & Internet
My computer burned 2 hdd
After i Read your Explaination,i really sure if the Problem is at your Computer POWER SUPPLY.
Change your Power Supply to Higher Watt.
i Recomended to you to Using SIMBADA Power Supply ATX.
and to Fix your HDD bad Sector,Try to use LLF (Low Level Format).
LLF will destroy all data and Partition.So after you Format using LLF,you need to make a New partition at your HDD.
LLF is Working for me to Fix Bad Sector in a So many times.
Jan 18, 2012 | Gigabyte Ga H55m D2h Desktop Motherboard...
1. read time of hard drive clusters is less than 500ms 2. 33% of hdd space is unreadable 3. bad sectors on hard drive or damaged file allocation table 4. boot sector of hard drive disk is damaged 5. hard...
You can run ChkDisk utility to fix Bad sectors on the hard drive(If its fixable).
This utility actually marks the bad sectors on the Hard drive and Isolate from the being accessed thats why 33% of HDD space is unreadable.(Which is very high)
There is no option to fix this HDD, so suggest you to replace it with a new one.
Hope this helps Let me know if you have any query on this.
Jun 23, 2011 | Computers & Internet
Bad sector problem, and hdd is not working proparly, hdd ditecting problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Nov 17, 2010 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
Many Bad Sectors fat32, trying recovery disk
It sounds like your HDD is faulty, usually a hardrive can operate with bad sectors but still a risk.
My best advice would be to get a new HDD and recover back on to the new one, even if you did manage to recover onto your current one you may still have problems in the future.
I usually only allow a HDD to fail S.M.A.R.T tests 3 times over any given period and then I just replace them.
Thanks
Sep 05, 2009 | Acer Aspire 3000 Notebook
How to remove bad sectors laptop hdd
Sir,
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
Hdd bad sectore problim
bad sectors are not fixable as far as hard drives go.
you mmight find software that claims ti fix bad sectors but the claim is false as they only temporarily overwrite the sectors and unmark the bad and remark to good but the problem remains to be the sectors are bad.
The best thing to do is to replace the hard drive with a good used one or a new one.
Sorry but as a technician I know what bad sectors are and what happens when you get them.
Jan 22, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Buffalo Technology (USA), INC. - 500GB DRIVESTATION EXTERNAL USB 500 GB Hard Drive Logo
537 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
