Question about MTX Thunder 1501D Car Audio Amplifier
I have a mtx thunder 1501d..i have the power cord connected from the battery, to a power cap and then to the amp...i have the ground connected to the metal frame of the car, to a power cap and then to the amp. i have the speaker wires hooked up correctly as well as the remote and RCA cords...my amp has a red dot..before i took it out the mtx symbol lite up red and not it doesn't but the amp works still..any help?
  • tonytone54 Jun 09, 2009
    then what is the negative post for on a cap? also i had it connected that same way in my previous car and it worked fine and the amp was working fine, now it just has the red dot.
  • 655 Answers
Hello tonytone54, The ground should go directly to the vehicle frame, never through a cap, fuse, or anything else. Also, if you are connecting positive through a cap, make sure that you charge the cap before connecting it. Hope this helps.
Posted on Jun 03, 2009
Transistors burning or getting hot small yellow non polorized filters in the out put area swollen(6)
there could be a list of problems... for one make sure you are using a ground cable 4awg or bigger and no more than 18 inches long this must be bolted to the body tight and a clean metal to metal connection. the ground must be the same size or bigger than your power wire. you should have at least a 150 amp altinator and a single dry cell battery. i use drycell to keep corrosion away. the longer your power cable the bigger it should be. at 20 feet you should run a 1/0 gauge power cable at least to a distribution block with the correct size to the amp. if your using a cap all cables must be the same size with the ground same size or bigger.
Jan 30, 2011 | MTX Thunder 1501D Car Audio Amplifier
1501d,, What subs should i use/
I would stick with Kicker or MTX. The best place in my mind to get them is soncelectronix.com
Just try to mach the specs as close as possible. Make sure to look at the recommendations of the subs for the size of the box and the port volume.
Oct 11, 2009 | MTX Thunder 1501D Car Audio Amplifier
Ran it at 1@ now it has low power
Hello if your amp is the one above in the picture, MTX-1501D then your amp is not 1 ohm stable. Your amp is rated at 500 watts x 1 at 4 ohms and 1000 watts x 1 at 2 ohms. The amp has a safety circuit that if it senses to low of a load, ohms, it will only put out half it's power to protect the amp from shorting out. Read the manual. You can download it at retrevo.com or just google it and a manual download site will be in the search list. Hope this hels, Good luck.
Aug 21, 2009 | MTX Thunder 1501D Car Audio Amplifier
My subs make a loud humm when I turn my gain up.
your ground has to be no longer then 2 feet if ot it picks up noise from rca
Mar 13, 2009 | MTX Thunder 1501D Car Audio Amplifier
Need help MTX 1501d amp diagram
Remove cover and set in direct sunny window for long time, may be no problem with it, Took a month to dry one of my amps out enough that it decided it would come back to life, cell phone dropped in sink took 2 weeks, If you try power to it too soon --fried--, good luck finding diagram and repairing it sincerely-hope its okay, good amp, bad luck,
Mtx thunder 1501d
yes you can not run amps with your speakers being grounded un ground and then try
Nov 26, 2008 | MTX Thunder 1501D Car Audio Amplifier
MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
Sep 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
Mtx 1501D
if your power light is on then check your preamps (sub out from head-unit).Maybe you need to turn on that output thru head unit's audio menu.Also when using dual voice coils if you wire them out of phase there will be no output
Sep 16, 2008 | MTX Thunder 1501D Car Audio Amplifier
Mtx 1501d
There are a lot of problems that can cause the amp to apply DC to the speaker terminals.
Before we go any farther, you should know that this amp stores enough energy to kill. When power is applied, the transistors must be clamped to the sink. After removing power, you MUST wait for ALL LEDs to go COMPLETELY out.
You need to CAREFULLY measure the DC voltage from leg 1 to leg 3 of all of the output transistors (the ones you changed). Post a list of the voltages and circuit board designation (FETxyz) for any that read more than 1v.
Do NOT let the probes short to other pins or to the heatsink when measuring the voltage.
Remember... High voltage and lots of stored energy. Be careful.
Apr 17, 2008 | MTX Thunder 1501D Car Audio Amplifier
Amp problem
These amps have a problem with broken shield connections on the RCA jacks. If the shield breaks loose from the frame of the RCA jack, you will have this problem. If you disconnect the amp from power and pull the cover, you can check to see if the shield is loose in the frame. if it is, it needs to be soldered.
You can also have this problem if the shield ground opens on the head unit.
Dec 06, 2007 | MTX Thunder 1501D Car Audio Amplifier
MTX Thunder 1501D Car Audio Amplifier Logo
306 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
