Question about Stanley Bostitch 00540: 00540 AntiJam ? Extra Heavy-Duty Stapler
B310HDS Stanley Bostitch stapler rod to lock stapes has plastic t
Tab and it is broken. Need to replace rod. Where can I locate? Very expensive to replace stapler for such a small problem.
  • Anonymous Mar 13, 2014
    manual is needed
I have the same problem and have found no answers from Stanley Bostitch customer service. They redirect to a telephone number that does not answer.
Solution: Don't buy Stanley Bostitch.
Posted on Feb 02, 2010
  • 6 more comments
  • rjg2012 Feb 06, 2010
    UPDATE:
    Never received a callback but was able to contact by email and they are sending the part out free of charge.
  • LimoTom Sep 30, 2010
    do you have the email you used to get in touch with stanley about the replacement rod?
    reply to WatkinsLimoTW@Hotmail.com if you can help me! ;>) Tom Watkins
  • rebelbibi Dec 29, 2010
    I have a Stanley bostitch Model B310HDS. When i started working here in this office, i searched for a heavy duty stapler. I found it, and it was being used as a door stop. I tried to use it and it was jammed. no one could get it to work properly. I guess that is why it became a door stop. I tried and couldnt fix it either. I agree with your post. 'DONT BUY THESE STAPLERS"!!!
  • soontobedean Jan 06, 2011
    Bostitch@stanleycustomercare.com - this is the email address to send a request for a new part to.
  • telwell Jan 13, 2011
    I also have a Stanley Bostitch Model B310HDS. It has never worked since I started at this job. It is jammed and the rod won't go in all the way and I can't get the staples that are in there to come out. What a waste of a very expensive stapler. I also think the design for loading this stapler is ridiculous!
  • Davy Jones
    Davy Jones Apr 03, 2014
    I used my glue gun and made a rubber band repair. Added glued on pieces allow the rubber bands to hold the rod in place. A spur was added to the rod base and a spur was added to the handle.mThink of a rubber band gun.
  • Davy Jones
    Davy Jones Apr 21, 2014
    Glue on a tab to the back of the spring cap. Rework a paper clip to loop over the tab as a lock. Anchor the paper clip into the hole on the rear of the handle.
    New Friend:
  • 40 Answers
Yeah, unfortunately, I think these were designed as "throwaway staplers" - I tried to repair one once and couldn't get parts (and I had lots of connections for finding parts at the time).
Posted on Oct 22, 2014
  • 3 Answers
I got 3 new red cap spring assemblies from Bostich Corp office by filing a complaint letter by email, fax, and postal mail.
I comment that Amazon Remarks label this as bad and it should be pulled from the market.
Posted on Oct 23, 2014
Get the glue gun out. Modify the rod and the handle so rubber bands can be used to hold the rod in place. Think of a kid's rubber band gun.....
Posted on Apr 03, 2014
Open and load staples b660
Hold on to the chrome part near where the staples come out and lift up on the top plastic part. There is a video link on the Bostitch site to the right midway down the page
Stanley Bostitch No Jam Premium Stapler B660 Black
Feb 08, 2015 | Stanley Bostitch B660-BK: NoJam Full Strip...
How do i load the Stanley Bostitch 00540
Hi Diane,
If you look at the back of the stapler, there's a bright red button. Push this in and slightly lift up at the same time, then magazine is withdrawn. Feed a strip of staples in and replace the pusher unit.
Bostitchtools co uk Bostitch Nailers Staplers Fasteners Coil Nails Staples
Jan 29, 2015 | Stanley Bostitch 00540: 00540 AntiJam ?...
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
Looking operators manual for stanley bostitch rn45b
Look here for manual and parts:http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=WM45B&serialNum=
The two lines of address above should be all one line in the address bar. If it does not work, go to www.bostitch.com , service parts and find wm45b. Good luck
Sep 18, 2010 | Stanley Pneu Roof Stapler
I HAVE A BOSTITCH NARROW CROWN AIR STAPLER AND THE STAPLES ARE NOT GOING FOREWARD FOR THE ROD TO DRIVE THEM IN. IS THERE SUPPOSED TO BE A SPRING BEHIND THE STAPLES TO MOVE THEM FOREWARD. PLUNGER COMES...
There is a spring to push the staples into place. Bostitch was purchased by Dewalt and moved their parts lists to the web address below. Enter your model number and order the parts needed. Good luck with your future projects.
http://servicenet.bostitch.com/
Sep 02, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
I have a model B310HDS heavy duty stapler and the spring mechanism broke on the end. Where can I find the replacement part? Thanks
what you are looking for what they call a pusher assembly.
Bostitch company uses Amex(SP?) for their replacement parts.
The phone number is 800-343-9329
Jul 21, 2010 | Stanley Bostitch 00540: 00540 AntiJam ?...
My Bostitch MIIIFS Floor Stapler wonk work
Sounds like you have a broken driver blade.
Sep 27, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Looking for the bostitch m111fs flooring stapler instructions
Go to the Bostitch / Stanley website http//www.cpobostitch.com/ Browse for the product as if you are shopping ot buy it. Under the Specifications tab you can download a Schematic and/or Owners Manual in .pdf format. Quick Link to Bostitch MIIIFS owners manual: http://www.cpobostitch.com/static/manual/miiifs.pdf
Jan 15, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Stanley Bostitch 00540: 00540 AntiJam ? Extra Heavy-Duty Stapler Logo
7,090 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
