Question about Karcher PSI Electric Pressure Washer
I have a karcher k3.91 which cycles on its own every few seconds and then leaks water from in side in unit, any ideas anyone on how to fix it?
  • Chris Bowden
    Chris Bowden Jun 22, 2009
    ok thanks for getting back to me, firstly without taking any covers off it leaks from the left side wheel looking at the machine from the front, after taking covers off it appears to be coming from somewhere around the on\off unit, but it happens so quick and comes out at such force its really quite hard to tell, any way of making it easier for me to locate the exact place of leak? man thanks chris.
  • Chris Bowden
    Chris Bowden Jun 23, 2009
    Hi there and once again thanks, I have now found the part thats leaking its the piece that the inlet and outlet both connect too, via the sliding clips, there looks as though theres a hair line crack in it, any ideas where i can get from and roughly how much would i be looking at paying, many thanks chris..
    Problem Solver:
  • 12 Answers
Will first need to know where the water is comming from, then yes i can help
Posted on Jun 18, 2009
  • 1 more comment
  • stephen perkins Jun 22, 2009
    yep, firstly take off the lance, pull triger, then turn the machine on then very slowly shut the triger, this will cause a slow increase in back pressure and you should be able to locate the leak a little easier, its common for the out let head to crack from around the bypass housing ( the bit that switches the machine down) just a short distance back from where the chemical tube fixes on
  • stephen perkins Jun 23, 2009
    yep, cleanstuff.co.uk, think its around £20,
If a washer not used for a few years would that cause any problems
Hi and welcome to FixYa, I am Kelly
The seals do have a tendancy to harden / dry out or... corrosion prevents the unloader bypass valve from moving / operating properly. I recommend you put a little oil (2 oz maybe...) through the unit on purpose via the inlet water connection. Then connect your water hose and force the oil though the unit with the air in the water supply hose while it purges. DO NOT turn the unit on until your sure the water supply hose has purged out all air. Then turn on the unit making sure that you cycle the wand trigger rapidly for a few minutes by cycling the trigger until the high pressure hose is not so rigid then let the high presure hose charge fully again. Cycle trigger wait, cycle trigger wait. 1 second bursts until you get full pressure. Then use normally. This usually wakes up pressure washers that have been resting :)
Thanks for choosing FixYa,
Kelly
Apr 18, 2011 | Karcher Garden
Karcher is spraying water from inside the unit, it actually a k2.97, any ideas please
Hi I have water spraying from air vent/intake on side of my k370 can you help ?
Mar 01, 2010 | Karcher K2.26 Electric Power Washer
Karcher 360M pressure washer pulsating problem when idleing
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head or the plastic valve block on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this. Hope this helps Kind Regards Brad
Dec 16, 2009 | Karcher PSI Electric Pressure Washer
I have a karcher 495, it is puslating when it is
It sounds like there may be a pressure leak somewhere in the system. The machine cuts off when there is no flow of water past it. If it is leaking then there is intermittent flow. Which would make the machine run then stop continuously.
Nov 15, 2009 | Karcher K 5.85 M Electric Pressure Washer
My Karcher (K2.26M) pressure washer is leaking water from the ON/OFF switch and the bottom. Does anyone know what could have broken, and what part I would need to fix it?
I have had a dozen of these units, My advice is not to bother trying to get parts or fix it. Its designed to be a throw away unit!
Oct 31, 2009 | Karcher K2.26 Electric Power Washer
Refrigerator will leak water every few days.
This water is probably that accumulated during the automatic defrost cycle, which occurs every 24-hours. A fan is supposed to pull air over it to evaporate it.
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
Aug 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Jun 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
New to this Machine. Unit washes and stops every 25 seconds?
Have you contacted Malber USA? 516-294-6660. They were helpful with my problem.
Aug 17, 2007 | Malber WD1000 Front Load Washer/Dryer
Karcher PSI Electric Pressure Washer Logo
825 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
