Question about GPS
There's a black line across the bottom of my screen which moves all info up about 1/4" and throws off selection of letters or numbers. Also just lately the screen brightness has dimmed. Can you help?
  • anastasia360 Jun 05, 2009
    I just did upgrade my GPS, but the line was there before I did that. The upgrade (new maps Etc) cast about 70 bucks. Worked fine except for the line. After help from Guru the screen went blank and we could not open the unit as was told. Therefore the unit is no good. I purchased a new unit today and am returning it tomorrow because I cannot turn it on of off unless it is plugged into my computer. Thanks anyway. Bob Gilby
    Scholar:
  • 62 Answers
GPS softwares have been changed lately and many of them need upgrades.
You need to upgrade your GPS software.
Go to the GPS company's website and look for the software. This should fix your issue.
Regarding brightness of your screen, it could have been told if you had mentioned your GPS company. But upgrading the software would set the default settings to your GPS in which case the brightness would be normal.
Good luck,
Please rate the solution.
~regards,
Jegan
Posted on Jun 03, 2009
Make letters larger
which program word or just internet web page ?
if you are using word open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial times new roman arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
if this is for a web page
right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
if you need more help with this post a reply with more information on the program for the size of lettering
hope it helps
Sep 08, 2012 | Computers & Internet
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
I have an old Sharp Model # 27A-S100 I have a Black Line running across the bottom of my screen from left to right 22 1/2" length and 3 1/4" in height
If this line does not go all the way across the screen then I will bet you this is an easy fix. Press the menu button on the remote control. The menu will hopefully show up over-top the black. Search your menu for the closed caption setting (usually under audio settings menu) and turn closed caption OFF. Hopefully this fixes your issue. Cheers.
Apr 24, 2011 | Sharp 27N-S100 27" TV
Blue line across bottom of screen on a Sony LCD rear projection
Contacted Sony Eletronics and was told it could not be fixed . Sony
offered a great deal to trade in for a much better one : a 55" Sony Bravia valued at $ 2,000 for $ 825 . Not bad !
Feb 05, 2010 | Sony KDF-E42A10 42 in. LCD Television
Dell monitor E172FPT HAS GOT BLACK LINES ACROSS THE BOTTOM OF THE SCREEN HORIZONTLY??
Click the Menu button and use the '+' & '-' signs to select restore factory settings. Check if you get the same line in the BIOS screen, if so then you would need a replacement.
Nov 14, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
The horizontal on the screen has moved i have a 2
i have same problem it happens with my hdmi and component port.
did you ever find out what the problem was?
Apr 07, 2009 | Sharp Televison & Video
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
Need sim number
1) Press the "menu" button to the left of the 4-way navigation button.
2) Use the 4-way navigation button to move to the "My Info" selection and select "My Info".
3) You now see a list of information that can be edited such as Name, Line 1, Line 2, etcetera........
4) Press and release the "Menu" button and a new screen/menu appears.
5) Scroll down to IMEI/SIM ID/SN and select IMEI/SIM ID/SN.
Jan 20, 2009 | Nextel i265
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
GPS Logo
67 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
