My Compaq keyboard has a key with an icon shaped like a moon. What is that for? Also, ovedr the number pad, there is a light on the right that has an arrow pointing down. What is that light for. Also, my screen keeps blacking out.
The key with the moon on it will put the computer to sleep. It shuts down, but is not "turned off" This means that it will restart quickly. The light with the arrow pointing down shows you that the shift lock is on. You probably have power saving turned on. I am assuming you are running XP. Right click on the desktop. Select properties then click on the screen saver tab. at the bottom of the screen there is a button for the power saver. click on it and increase the screen blackout time (or set it to never)
The Moon key is for putting your computer to sleep, the keypad light is probably the NUM LOCK LIGHT.
When your screen blacks out will it come on again if you press enter on click the mouse button? if so, go into the control panel, click on the power options and look for the icon marked 'Screen' or something similiar. Change the timing to an hour or so...
Which Kensington trackball is better -- 64210B or 64213 or K64325? Which one has the least number...
(More)
Which Kensington trackball is better -- 64210B or 64213 or K64325? Which one has the least number of issues in terms of breaking down, and has the most options?
Margaret
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your...
(More)
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your criteria. It costs less than $65.00 and is easily connected to replace a wired keyboard and mouse.
I have been using two of them for years now, and have never had a problem with them.
They eliminate excess wires, and work like a charm.
Nothing happens when I hit the ''enter'' key on my keyboard - can you help? I use a laptop with an...
(More)
Nothing happens when I hit the ''enter'' key on my keyboard - can you help? I use a laptop with an external keyboard - the enter key on the actual laptop works as it should - but for some reason the enter key on the full size keyboard isn't working - I think I might have mistakenly hit something which caused it to go dormant.... Can you help?
How do you change the default mail program for the mail multimedia button from Outlook to Outlook...
(More)
How do you change the default mail program for the mail multimedia button from Outlook to Outlook Express
One of the little "feet" that props up the keyboard broke off. Where can I buy a...
(More)
One of the little "feet" that props up the keyboard broke off. Where can I buy a replacement for that?
