Question about Sony Playstation 3 (PS3) Console
Ps3 i went on the settings on the ps3 then i went on display it then asked me to tick the boxes for what resolusion my tv could work asmany as was true. i then pressed squre to test it and the screen went blank. ive turned it of a number of times but the picture wont come back on.
  • Anonymous Dec 26, 2007
    my screen is blank but the ps3 is on
  • Jourdan Dec 26, 2007
  • 1,463 Answers
 see hear for more info on how to resolve this
Posted on Oct 25, 2007
My Playstation 3 has stopped playing speech sounds properly. On FIFA there is no commentary or David Hayter EA Sports intro. And in Metal Gear Solid 4 during the cutscenes as well as the Codec, most speech...
I hope this helps:
On the XMB, go to
Settings; Display Settings; and choose Video Output Settings.
- Click Video Output Settings.
- Choose HDMI
- Choose Custom
- Tick all of the boxes - Only the ones that your TV supports.
- Move on and the PS3 will test the settings. Screen will go blank and return.
- Press X to save settings.
- When it has finished saving the video settings, choose "Set Audio Output Settings"
- Choose HDMI
- Choose Manual
- Tick the boxes that your TV can support and move on and save settings.
Tip: If you aren't sure which ones your TV supports, go back and choose Automatic and then Press Enter to save settings.
If it fails, call Sony. If its a particular game, then maybe a patch is needed for that game.
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Out of range
Right i'm halfway to understanding what's going on.
It sounds like your ps3 is readjusting the resolution to something the new tv isn't compatible with.
Looking at the t.v (bravia v4000), it should be compatible with all resolutions upto 1080p.
What happens when you turn the ps3 on initially (plugged into the new tv) ? It doesn't go straight into the game, so what happens and what boxes in the display settings do you have the resolution set to?
You should only have 720p and 1080p ticked.
The 40v4000 supports 1080p so when the PS3 auto-detected the display settings it set the XMB to 1080p, the 32v4000 supports 720p but the PS3 still thinks its connected to the 40v4000 so it is trying to output 1080p which is out range of the 32v4000. Go to the display settings on the PS3 and auto-detect the display settings again
Feb 13, 2010 | Sony Playstation 3 (PS3) Console
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
I'm programming a blue ray recorder and the wizard setup is asking what res 10801 or 1080P, also aspect ratio of16.9 full or 16.9 normal
IF tv can take 1080p use this setting you will see blank screen if not the blu-ray will set up the best resolusion for tv usely auto mode and the ratio dipends on what size screen you want to watch playback in
Nov 08, 2009 | Hitachi 42HDS69 42 in. Plasma Television
No sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Jul 19, 2008 | Televison & Video
to any future people with this problem disable 1080i from supported resolutions check 720 P and 1080P only, ps3 doesnt have good 1080i support
good luck
Oct 15, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
82 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
