Question about Emerson Microwave Ovens
Hi.it just went out,no power what so ever,tryed
Hi.it jst went out,no power what so ever,tryed replacing the fuse ,no good still does not work>?
  • 6,784 Answers
Try replacing the high limit capacitor. this is a common issue in this situation.
Posted on Jun 04, 2009
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
No Power
hi,
Did you try replacin the fuse.It might have blown.
Jul 03, 2008 | Sharp R-930AK Convection/Microwave Oven
Amana MVH210W keeps blowing fuse
The magnetron is more than likely the problem, or the inverter board if oven is 7 years old or less. If you have a digital meter you can do a rough test on the magnetron, unplug microwave, set meter to ohms, disconnect one wire from magnetron and put the test leads across too points, if reading is .2ohms or less it is good, but if the test shows infinity or open the magnetron is bad, keep in mind it may have a short making the reading misleading.
Jun 04, 2012 | Amana Microwave Ovens
Went to use microwave and it just went dead. Household power is fine and breakers are good. Replaced main fuse behind switch panel and got power back for clock etc.. When I went to run it again, it went...
short circuit in high tension power supply
DUE TO THE VERY HIGH AND DANGEROUS VOLTAGE 4000( V) IT IS NOT WISE TO FIX IT YOUR SELF UNLESS YOU KNOW WHAT YOU ARE DOING
Apr 26, 2010 | Maytag MMV5100A Microwave Oven
Turned on the microwave and all power just went out. Checked the breaker panel, but none are tripped.
when you said the power went out ( did you mean to the micro or the complete hm . if only to micro it probably blew it internal fuse . they doo that . replace the fuse ( radio shack is a good place to get it .) but ck the door inter lock's as they may have caused the failure . ps buy more than one fuse / you may need more. **** ,,
Dec 23, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Hi, When my GE jvm1650bb microwave starts, it begins to work and then blows the fuse in the house. Does this every time, the circut is not overloaded. Is their a part that went bad that I can replace?
Try your oven on another circuit in your house. It is curious that your oven doesn't blow its own fuse before the house one. If it doesn't blow the fuse in the "new" circuit, check to see what is really on the kitchen circuit. It might, in fact, be overloaded. Good luck.
Nov 28, 2009 | GE JVM1650 1000 Watts Microwave Oven
Had microwave about 10 months GE wes1450dm1bb went off then came back on after it sit awhile then went out again and never came back on again no lights or power at all please let me know something to do...
Look first at the fuse inside the cabinet - unplug the device first of course. Do not touch the silver can - Lethal.
Check the fuse with a ohm meter of other contunity checker.
It could be the SILVER CAN. In the past, I have had success by simply unplugging the VERY HIGH VOLTAGE (25,000 <> volts) connections and reconnecting them. This silver can potentially has enough power stored it in, even months after being unplugged, to kill. If you dont know how to short it to ground SAFELY, pay someone to repair it.
Find a replacement fuse at the hardware store.
I hope this helps you ... I hope it is the fuse.
a
Oct 04, 2009 | Microwave Ovens
No power to oven after removing light bulb
What happend is that when the bulb broke the filiments touched (shorted out) and caused the reset switch on the unit to set>>>you need to find the reset button on this unit, look at your service manual. Additionally on some units there is a fused link internally, that may have blown>>>>both are an easy fix, so dont throw it out.
Good luck,
Geodesy
Sep 22, 2009 | LG Over-the-Range Microwave
Ge microwave blows fuses, replaced fuse after hiltonjug's excellent advice and the next day it went through another one, doesn't sound good. Thanks, Jeff
have you checked/replaced the : HI-Voltage capacitor,the HI-Voltage Diode, and checked the unit for current draw while its in operation?these are three main components of fuse failure
Sep 06, 2009 | GE JVM1330BW/WW Microwave Oven
Need help
1. Have you tested the outlet by plugging in something else and confirming that the outlet is good? If another device doesn't work in the outlet, then you have a bad fuse or breaker that powers that circuit in the house.
2. If power is OK, you probably have a bad fuse in the oven. You'll need to unplug the oven and remove the outside cover. Replace the fuse with the EXACT same rating of fuse of the original.
Please get back to me and let me know what you find.
- Jim
Feb 12, 2008 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
