Question about Whirlpool LER4634J Electric Dryer
The timer is stuck indefinitely on "Cool Down" and never turns off
  • 6,784 Answers
HI, this is defiantly a defective timer mechanism. you will need to replace the timer/control asap. It has failed.
Posted on Jun 03, 2009
My maytag atlantis gas dryer will not turn off at the end of the cycle
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Mar 23, 2016 | Maytag Dryers
Fridgedair gleq332a52 won't stop heating
Oct 16, 2014 | Dryers
Won't. Shut off
Oct 02, 2014 | Dryers
My LG Dryer still runs when it is off and when I turn it on it says to check filter
Sep 23, 2014 | LG DLEX3875V Dryer
Fisher Paykel dryer won't shut off. Dial not moving. Would this be the timer, sensor, or soething else?
Sep 21, 2014 | Dryers
How to fix aFisher & paykel dryer coils are on when dryer is off?
Aug 22, 2014 | Dryers
Hand dryer won't shut off
will not shut off:
Aug 14, 2014 | Dryers
GE Profile dryer keeps running and timer switch doesn't move
Aug 13, 2014 | Dryers
Dryer works but when time is up it keeps running (cold air)
Aug 13, 2014 | Kenmore Dryers
We have a General Electric WJRR4170E1WW top loading washer that occasionally hums when it is running but the agitator doesn't turn. When it does this it will go all night in this mode and get stuck. We can...
sound like a stuck timer does it in all cycles!!!!!!!!!! permanet press cycle , regular cycle
if it does it in all cycles then definetly timer...
Jan 31, 2011 | Washing Machines
Whirlpool LER4634J Electric Dryer Logo
152 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
